Roadrunner Jr.
Aside from the vented/ported space requirements and powerhandling/sensitivity changes of a speaker in a ported enclosure...the group delay idea is fairly new to me.
I'm wondering...in reality...are we going to hear a difference between a two properly constructed enclosures (ported and sealed), everything being equal, in the realm of response time? If the amplifiers have good control...wouldn't the added "sensetivity" of the ported enclosure make it inherently more loose when dealing with equal sized woofers? Then again, we have to wonder to what specifications the ported enclosure is built...I know darnwell I've heard some tight ported enclosures. *sigh* And then on the other hand, that "tightness" may have been from the added output amplitude rather than physical control. The problem is that you MUST give something to get something. For the quick response of the ported enclosure, what do you have to have? A bigger, more elaborate enclosure (which is a given versus a sealed enclosure), or do we loose power handling and/or frequency response? What do we give up here? That in itself is enough for me to stick with a sealed enclosure's benefits of space savings. Mind you, that's MY preference. A 15" woofer in one cube with plenty of power sounds just sexy to me... Let us talk more on this specific subject though, its interesting.
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine |
#2 | ||||
Audio Junky
Group delay is basically the time that the coil takes to get saturated and reverse its directions.... so... how long it takes for it to stop, and start. The quicker it can do that, the cleaner the sound. The T/S spec that you can check to guesstimate if the GD will be good or bad is the (Le). Also... tuning a sub low will also help keep GD spikes down. Quote:
I forget exactly what it is... but physics states that a speaker will need an ever increasing box size the bigger the speaker gets.... It has to do with the Surface area (SD) of the speaker & the Vas I believe. If you double the cone area, I think the speaker would require 4 times the box size....all other variables staying the same of course. I might be a bit off on that tho.... Regardless... in the space that you could fit a single 15" sealed woofer... I could probably fit 4-6 similarly spec'd 8" subs.... would have less cone movement, & probably higher efficiency... meaning... louder & less distortion. Like I said... I really want to spend 30mins to an hour showing you the joys of box modeling and what crazy shit you can do with a driver. I've got a copy of a really nice program. |
| is it possible to know the RMS watts oem-deck output? | yv1650c | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 05-05-2007 01:42 PM |
