Old 08-20-2009, 03:07 PM   #1
OK. So right now your SRS light is off, air bag off is lit, and passenger seat belt is lit?
Try disconnecting the battery for 2 minutes, reconnecting and then measuring the voltage on the center pin to ground. for a really solid ground you might want to pop the passenger kick panel and touch the black lead to the ground bolt there.
Old 08-20-2009, 03:13 PM   #2
MGargano
Drives: 2009 Yaris Hatchback
No, sir. All three lights, including the SRS, are still lit.
Old 08-20-2009, 03:32 PM   #3
Here's what I've found with the oscilloscope - Every 100ms the sensors transmit a packet of data. The beginning of the packet is always the same and the latter part varies based on pressure on the sensor.
Here are two sequential data packets from the front right sensor:
Here is one packet with no weight on the sensor:
Here is one packet with enough weight on the sensor for the airbag light to be lit:
Based on this I can easily build a module to simulate the sensors (and to switch between an empty and occupied seat).
Old 08-20-2009, 04:21 PM   #4
MGargano
I just tried this and registered nothing with the meter set to VDC. When I moved it to 200k ohms, it registered 6.0 between the center pin/wire and ground.
Old 08-20-2009, 04:51 PM   #5
It really looks like your OC ECU is not responding. Take a close look at all of the wiring to and from it. Look for any sign of a damaged wire.
Old 08-20-2009, 05:57 PM   #6
MGargano
I don't see any signs of damaged wiring or anything else out of the ordinary. I can't think of anything I might have done to damage it (dropping, etc) so I hate to think there's a problem with it. Should I start looking for a replacement?
Possible Group Buy.. Racing Seats, Intakes? TinyGiant Items for Sale by private party 60 09-11-2009 02:40 PM
FS: Recaro Pole Position Racing Seats (black) -- socal 03Z33 Items for Sale by private party 13 12-07-2008 05:08 PM
sparco seats and pedals (pics) turboyaris Cosmetic Modifications (Exterior/Interior) 18 09-05-2007 02:43 AM
Sport / Racing seats worth the while? mikeukrainetz Cosmetic Modifications (Exterior/Interior) 10 11-19-2006 01:17 PM
Yaris Liftback Seats artyin General Yaris / Vitz Discussion 3 04-30-2006 04:07 PM
