#1 | |
Drives: 2009 TOYOTA YARIS SEDAN Join Date: Aug 2009
I would think that if you mounted them in the standard fog lamp position they would be too low to have any effective use as regular headlights. I had a Mustang that I mounted 100w fog lamps on a switch to either side of the pony in the grill to use as headlights since I had headlight covers. They seemed to work but they were real bright, and I only got pulled over once... for forgetting to turn my regular headlights on...! Paid maybe $50 for them. |
#2 | |
ellenbetty
Drives: 2 2007 Yaris 3 door liftback Join Date: Nov 2008
Plus I suffer from neck, back and shoulder injuries from being hit by a van while in the USAF. So labor cost is also part of my question. If I lived in Maryland, I would just call Pep Boys and make a appointment to get the fog lamps installed. Maybe I should have added a question about where to buy the fog lamp and then have the fog lamps installed. Dealer would be a choice for OE fog lamps. |
The Fog lights Garm sells , are real easy to instal , 98% plug and play
just fit the lights and splice in 2 wires your done . Or you could spend another $170.US approx and buy the OEM Light stalk for the steering colum and be totally plug and play . the whole instal takes about 2 hr's . i would do it for you but your a bit far away . maybe another member on here might be willing to help you out . |
ellenbetty
#5 | |
![]() or i would be over there already
Right beside you, wave
Drives: 08 PBM Yaris Sedan Join Date: Oct 2008
please don't do it. I hate the truck guys who do it. And as said before, police will pull you over for it. I only use it when leaving my apartment complex at night to not shine my lights in my neighbors houses. After it get to the main road, I turn on my headlights.
![]() 2008 Toyota Yaris Sedan. Pacific Blue Mica. Custom vinyl eyebrows, color matched interior trim pieces, Vios lip spoiler, 17" Maas rims 2010 Scion xB 7.0 Release Series. 1535 of 2000. Murasaki. Stock with TRD springs. |
ellenbetty
I am not talking about a bunch of lights on top of a fake roll bar. My brother had fog lamps installed behind the grill of his Ford Ranger. I forgot about that. Higher but harder to install. But the fog lamp would have to put out about the same lumes and cover about the same area as low beams to do what I want. Fog lamps with the same output as high beam head lights would not be what I want. The built in mounts for OE equipment is not the only place I could mount the fog lights.
#9 | |
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
Exactly. Not the roof ones. It isn't that hard to replace a $12 bulb in our housings. Just reach in and twist.
| HELP!!! I went back to the service center yesterday for the 7th time in 2 months! | Meldav86 | General Yaris / Vitz Discussion | 27 | 08-21-2007 09:04 PM |
| DIY - HID Retrofit | Violin | DIY / Maintenance / Service | 57 | 06-11-2007 06:17 PM |
| Did you order fog lamps? | Driver | New YARIS Purchase Forum | 27 | 11-29-2006 06:27 PM |
| Where to find Yellow capsules for fog lamps? | W.A.S.P | Cosmetic Modifications (Exterior/Interior) | 0 | 11-26-2006 01:01 AM |
