#1 | |
![]() ![]() ![]() Drives: Silver 2007 3Dr - Gryph Join Date: Jul 2007
6db is roughly twice the physical sound pressure change, but it's 10db for an apparent sound volume doubling for our ears, that's what the scale is actually calculated against: Every 10db = double the loudness to our ears, which ends up being about 3.16x the physical pressure at each doubling of apparently loudness. And you get a lot more than 2% of the sound from the rear speakers, the problem you have to bear in mind is that sound is not a single fixed entity: You have various frequencies to deal with, and the most easilly damped frequencies are the highs. Those get muffled severely by your front seats when played through the rear speakers, though you can adjust for that. You are still (in effect) playing the speakers through a pillow, so it's vastly less efficient than using a good set of front speakers. A single pair of front speakers is the most efficient setup for stereo listening. I'll say that by itself so it's clear I'm not trying to say otherwise. But it is possible to set up a pair of rear speakers to sound very good too, if you have a reason to invest the added expense and time to do so. It's far more expensive either in time or seperate equalizer components for the rear and front than just slapping a good pair of speakers in the front and calling it a day.
#2 | |||
Audio Junky
4 speaker setups have a lower SQ potential than 2 speakers, UNTIL you start getting into DVD setups. Also.... I went to the Official DB Drags website.... and here's what they show for the loudest vehicle ever.. http://www.termpro.com/asp/worldreco...on_Select=2009 Its in the 3+ subs category.... the single woofer category wasn't nearly as loud. |
#3 | |
![]() ![]() ![]() ![]() Drives: Black HB Join Date: Oct 2008
Audio Junky
probably.... tho in my defense, in your glow gauge post you were unwilling to work in the rain.... sounds like most people to me.
well in my defense, im made of sugar. i would have melted. :P
Audio Junky
but once the sun came out.... you would've solidified and all would be good... cept you'd been in the shape of a pancake.
| Is worth it to replace only front and rear speakers? | tealio | In Car Entertainment + Electronics (audio / video / alarm) | 35 | 04-16-2010 09:11 PM |
| Factory deck, new speakers sound no sound?? | alan1828 | DIY / Maintenance / Service | 4 | 10-25-2009 03:36 PM |
| Fitting rear speakers in Toyota Yaris | nish1979 | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 03-22-2009 11:56 PM |
| Speakers make noise when engine is on | Lafiro | In Car Entertainment + Electronics (audio / video / alarm) | 13 | 01-07-2009 08:52 PM |
| Matching up right speakers for 4DR Yaris.... ohms match up? | ebowers83 | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 09-13-2006 11:12 PM |
