Old 08-23-2009, 02:32 PM   #1
RedRide
RedRide's Avatar
"A little knowledge is a dangerous thing"
All the so-called "horror stories" aboput Seafoam soley concern putting Seafoam in the oil, sucking it up thorough vacumn lines etc, by people who really do not know what they are doing.
There are absoluly no problems connected to Seafoam when putinng it into the gas tank, only benefits.
It's simple, just pour it into the gas tank. It's fool proof.
Keeping injectors clean should be a part of routine maintenance and whether you use Seafoam or some other sort of qualty injector/ fuels sys cleaner, just do it and stay clear of all the mis information.
The cleaners in gas are totally inadiquate for the long haul and some suplimental cleaner must be added on ocasions.
Old 08-24-2009, 12:12 PM   #2
supmet
Drives: 2007 4 Door Yaris
http://www.greatlakes4x4.com/showthread.php?t=59631
you gotta be careful with those products. my buddy used engine flush one time and all the shit in his engine plugged his oil screen and blew his motor.
http://www.jeepforum.com/forum/f197/...ont-do-836782/
Turns out the seafoam broke all the slidge loose in the tank and cloged the pickup screen on the pump so bad it could not suck any fuel through it.
http://www.benzworld.org/forums/w202...-additive.html
With that in mind I decided to added the SeaFoam to the gas tank rather than directly to combustion chamber via the brake booster vacuum tube.
After adding the product the I drove the C280 about 30 miles. The car ran really well and had rock solid idling.The following day my wife was driving the C280 and after a short trip to the store,she parked the car. Upon returning to the C280 and starting it, she noticed immediately that the car was idling very roughly and the CEL light came on. Driving home on the highway at highway revs , the car had smooth acceleration and drove as it normally does. Only at idle was it rough. Tried to drain fuel from Benz but needed a longer tube to siphon the gas. Decided to just use up the fuel ( full tank ) and see if it will "correct" itself as was the case with the 99 'Explorer
I drove the car this morning, and expected a rough idle at startup. Surprisingly, the car idle like a watch , this AM and during my initial 47 mile commute to work performed as it always does ( plenty of power and smooth running ). Once again ,upon leaving the highway and entering the city and having to stop I noticed that the rough idle has returned. CEL light is still on
I'm thinking fouled plugs or a fouled O2 sensor due to the carbon or guck in the combustion chamber being removed. It's strange that this morining at start up ( and for a while afterwards ) it idled beautifully. Only after the commute and entering the city , where I'd have to stop for stoplights did it idle roughly . Weird.
gas tank fool proof what???
I don't really have anything against seafoam, just 3 people recommending it without knowing ANY symptoms besides loss of power, and NO attempt to diagnose or check anything else.
kind of like having extremely limited knowledge about dude's car and recommending seafoam - right?
Toyota projects first operating loss since 1941 KCALB SIRAY General Yaris / Vitz Discussion 26 12-23-2008 03:37 PM
