Old 08-23-2009, 10:59 PM   #1
changchewsoon
Drives: Vios Turbo
Send a message via MSN to changchewsoon Send a message via Yahoo to changchewsoon
i suppose you were referring to the compression ratio for the pistons?
they are 9.0 pistons.
454 whp, 1.7 bar boost, pump gas, water/meth.
501 whp, 2.2 bar boost, pump gas + avgas, no water/meth.
www.viosturbo.com - World's first 500 WHP 1NZ-FE
changchewsoon is offline   Reply With Quote
Old 09-26-2009, 03:31 PM   #2
changchewsoon
Drives: Vios Turbo
Garrett GT2554R
They arrived a couple of days ago.
Old 09-27-2009, 08:05 AM   #3
Giupo
Drives: Yaris
Are you sure that your Cp pistons are 9.0:1 compression ratio???
Because my Cp pistons 9.0:1 compression ratio are more different.
This is my pistons:
Giupo is offline   Reply With Quote
Old 09-28-2009, 01:03 AM   #4
changchewsoon
Drives: Vios Turbo
This is my pistons:
Hi Giupo, yes I'm pretty sure they are 9.0 compression pistons as per stated in the invoice from CP. Well, unless CP is stating it as 9.0 compression and giving me something otherwise????
I noticed your pistons are deep dish design whereby mine is flat top design. Wonder what differences are they going to make?
By the way, I got my pistons skirt coated as well for 20 bucks extra.
Old 09-28-2009, 06:33 AM   #5
Giupo
Drives: Yaris
A dep dish desingn is a low compression ..have you pistons specification?
more picture :
Old 09-28-2009, 07:32 AM   #6
changchewsoon
Drives: Vios Turbo
My pistons are with my tuner now, I'll stop by to get the specification sheet from him tomorrow if possible.
This is what was printed in the invoice when I bought the pistons:
MEMO: DUP XTP-539P755 EXCEPT 9:1
CB-810C-4: CP CUST IMP 4-VR F/T#
CB-PF: PIN FIT PISTON
CB-708225015C1C: 4130 PIN:708x2.250x150/18MM-CHAMF
CB-SKIRTCOAT: TEFLON SKIRT COATING
CB-N2972: XC/GN RING SET:75.50mm/1-CYL
CR-B93725B-4: CRWR BILLET ROD:TOYOTA/SCION 1NZ-FE
I guess the F/T means the flat top design for the pistons?
Custom Axleback - Pics and vid. largeorangefont Performance Modifications 34 07-03-2014 01:59 PM
1000watt Custom built fosgate Sub box id3379 Items for Sale by private party 0 11-30-2008 04:29 PM
DIY: Custom Hidden Trunk Box (08 Yaris 3D) goku87 In Car Entertainment + Electronics (audio / video / alarm) 0 10-19-2008 05:43 PM
Custom Intake 07typeS Performance Modifications 39 07-26-2007 01:01 AM
How much has your custom exhaust cost you? whooppee777 Performance Modifications 7 07-21-2007 11:20 AM
