Old 08-24-2009, 03:47 PM   #1
I received the Eggo Waffle box today (and it was lacking waffles). I did a quick test of your OC ECU and it is fine, which means that the issue is either with one of the sensors or a wire. I'll check it out tonight to find out for sure. Either way, it won't really matter, as I'll be shipping it back to you with one of my sensor bypass modules.
Do you want me to clip the harness off and tie it directly to the module, to keep things neat under your seat? (I'll ship back the rest of the harness with the sensor connectors).
Old 08-24-2009, 05:32 PM   #2
MGargano
Drives: 2009 Yaris Hatchback
Glad it arrived ok and sorry for not including some waffles
Glad the ECU is working since it saves me time and money of getting a new one.
Yes, you can connect the bypass module directly to the ECU to save space and neaten things up under the seat. I'll hang on to the sensors and wires in case I go back to stock at some point.
Also, if it matters, I'm planning to mount the airbag switch in the center console near the e-brake.
Thanks!
MGargano is offline   Reply With Quote
Old 08-24-2009, 11:05 PM   #3
Thanks!
OK. Your module is ready to ship! I'll send it off tomorrow (to the return address on the waffles).
I checked out your sensors and cable tonight as well. The sensors are fine. The sensor connectors on the cable are the problem. When you probed some of them, you forced the probe in enough to damage the pins. So, if you ever go back to stock, you'll need to replace those ends.
Old 08-24-2009, 11:13 PM   #4
MGargano
Awesome! Damn that was fast! I'm glad the ECU and sensors are good. Do you, by chance, have a part number for the sensor harness, in case I want to order a new one?
Also, did you get a chance to look into the push-button stuff I PMed you?
PS- How much $$$ do I owe you for all this?
Possible Group Buy.. Racing Seats, Intakes? TinyGiant Items for Sale by private party 60 09-11-2009 02:40 PM
FS: Recaro Pole Position Racing Seats (black) -- socal 03Z33 Items for Sale by private party 13 12-07-2008 05:08 PM
sparco seats and pedals (pics) turboyaris Cosmetic Modifications (Exterior/Interior) 18 09-05-2007 02:43 AM
Sport / Racing seats worth the while? mikeukrainetz Cosmetic Modifications (Exterior/Interior) 10 11-19-2006 01:17 PM
Yaris Liftback Seats artyin General Yaris / Vitz Discussion 3 04-30-2006 04:07 PM
