Old 08-25-2009, 09:55 AM   #1
Keith Tinari
Scrubble with a poke.
Keith Tinari's Avatar
Drives: 2009 Yaris LB
So Im guessing they may not be the best option for me? I was going to do them for pure aesthetics to make the track look a little more even. But even now I rub when someone else is in the car. Only the R/R but it still rubs none the less. Mine are 15x7.5 +32 with a 5mm on the front and rear. I was going to lose the 5mm spacer in favor of a 13mm PG spacer.
"If you cannot find truth right where you are, where else do you expect to find it?" Dogen
Keith Tinari is offline   Reply With Quote
Old 08-25-2009, 11:56 AM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
what springs are you running? at the track, having weight removed from the car will help with the rubbing issues. also remember that you're compressing your suspension on the highway going over bumps. when you corner with a trailing arm type suspension (torsion) the compressed side of the car will tuck into the fender as the rear torsion beam flexes.. this means if you rub going over bumps, you may not rub as much going around corners :)
Help with wheel spacers.. lilred08 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 04-26-2009 07:47 PM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 08:52 PM
I need help w/ wheel spacers...Open Mic lol Stargate YARlantIS Wheels, Tires and Suspension Forum sponsored by The Tire Rack 21 12-06-2008 05:27 PM
