Old 08-25-2009, 10:43 AM   #1
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
Hmm I'm guessing you have the liftback? I don't see those clips anywhere on the sedan :(
Old 08-25-2009, 01:39 PM   #2
Jochen
Jochen's Avatar
Drives: Yaris D-4D
Yes, it's a hatchback.
Jochen is offline   Reply With Quote
Old 08-25-2009, 03:01 PM   #3
47_MasoN_47
I figured it out for the sedan.
Open the trunk and remove the 2 rubber plug things that hold the cloth cover to the inside of the trunk lid. Pull down on that slightly so that you can see the 2 wires that go to the bulbs for the lag lights. Twist, but not too hard, and it should move about 1/4" or so. If it seems to be taking a lot of force twist it the other way. Once it moves the 1/4" or so it should just fall free, then you can disconnect the bulb housing deal from the wire and pull the bulb from the housing. It took considerable force to get the bulbs out for mine. Then you can put the new bulbs in and you are good to go! I'll take pictures of mine tonight when it gets dark :)
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
How many forum posters does it take to change a light bulb? silver_echo Off-topic / Other Cars / Everything else Discussions 25 06-27-2011 01:50 AM
Led taillight bulbs casterqc Cosmetic Modifications (Exterior/Interior) 27 09-15-2007 01:48 AM
Side Turn Signal Lights bigsky2 Cosmetic Modifications (Exterior/Interior) 15 08-24-2006 06:06 PM
