Old 08-25-2009, 07:29 PM   #1
Yes, a larger front sway bar on a fwd will induce more understeer, correct?
Old 08-25-2009, 07:45 PM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
not necessarily. the real problem with a huge front swaybar on an open-diff car is your corner exit is destroyed by inside wheel lift (spin) throwing away your ability to put power down mid turn or even after the apex.
on high speed courses this should not be a problem though, as momentum carries you thru the "front wheel lift" portions of the corner (as long as you know how to drive)
Old 08-25-2009, 07:54 PM   #3
Ah, I see. I didn't know that. Thanks for sharing.
Which front bar do you prefer? Strut or Sway? TitaniumBarbell Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 10-16-2009 11:52 AM
Stock Front Sway bar kngrsll Tracking, Racing, Auto-X Forum 4 07-04-2009 07:01 PM
Yaris 24mm Front Sway Bar bikegerm Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 06-09-2009 02:33 PM
FS: NEW C-One Front Sway Bar & 4-Point Brace NEW LOWER PRICES! 03Z33 Items for Sale by private party 1 06-06-2009 01:29 AM
Question about Sway Bar! Ton Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 01-06-2009 03:31 PM
