![]() ![]() Drives: 2008 Yaris HB Join Date: May 2009
If I go 0w-30 in the winter which synthetic brand would you guys suggest? I used Mobil 1 last winter.....
![]() ![]() ![]() Drives: Blazing Blue 08 liftback Join Date: Dec 2008
Amsoil Signature Series 0w30 is good for 17500 miles or one year under severe conditions (35,000 miles or a year under Normal conditions). As an AMSOIL dealer I hope you'll go to TruLube.com and check it out.
Lots of oil info on this forum, use what s best for you.
One Year One Oil-AMSOIL at www.Trulube.com TRD Exhaust, Springs and Struts. TRD SSK. NST Underdrive Crank Pulley. Amsoil Dominator 10w-30 Racing Oil, Amsoil DOT4 brake fluid, Amsoil Severe Gear 75w-90 transmission oil, Ultra Racing 23mm Sway Bar, Camber Bolts, R1 Drilled Slotted front Brakes and SS Brake cables from Micro-Image. Orange Konig Daylight 17s, Kumo MXs. Greg@TruLube.com |
![]() ![]() ![]() ![]() Drives: 08 3DR 5M Bayou Blue; 09 Fos Join Date: Oct 2008
Did you use M1 AFE or just plain old M1? Most people like Penn Plat, but Edge now the price is down should "slaughter" M1. ExxonMobil tend to use group iv PAO base oils which do have good cold flow but do NOT have good wear or solubility characteristics. You'll see high Iron wear and engine noise complaints about M1 all the time.
