Unfortunately no European made Yaris prior to 2012 had cruise control. It was not until the 3rd generation with the 1.33L engine that Toyota added it.
Yaris = <3
Drives: '08 Sedan - Flint Mica Join Date: Jan 2009
I'm sure I could find a cheaper version at a local shop... going to check one out my friends suggests maybe today or tomorrow.
CTScott, Does this diagram suit the setup? I know it's not proper... I don't know what diagrams really should look like and all I had was a screenshot from the pdf and Paint to work with
..:'; Nick ;':.. ============================== 2008 Yaris Sedan - Flint Mica ============================== Debadged Rear; Blue Interior Styling; Toyota Sports Pedals; AM Exhaust Tip; OEM Spoiler; Upgraded Speakers; Sony Xplod BT 2600 Deck; Infinity Basslink SUB/AMP in Trunk; 16" Konig Rims; 6000k HID Bi-Xenons; 6000k HID Fogs; NST Short Shifter ============================== |
#3 | |
![]() Drives: 08’Yaris Join Date: Oct 2009
![]() Drives: 2007 2DR Yaris Join Date: May 2009
Hey just a quick question for you guys: has anyone done it on a 2006 yaris? I thought it was still the Echo, hence I wrote in the DIY that it was for the 07-08...
Yaris = <3
Nice! I'm very excited to add this in =D I like the idea of the little 4-way switch more than the stalk though. Will look much cleaner =D **stoked**
I wonder if it is mechanically limited to the 90 degree positions or if you can accidentally press two switches at the same time with a 45 degree motion?
#10 | |
Yaris = <3
Technical/Catalog Information 500-526 Vendor APEM Components Category Switches Type Navigation Switch, PCB Mount Actuator Type 4-Way Selector Switch Function 2 Axis Output Mechanical Switch Operating Force 100gf Contact Rating @ Voltage 0.05A @ 24VDC Termination Style PC Pin Lead Free Status Lead Free RoHS Status RoHS Compliant Other Names 500 526 500526 679 2289 ND 6792289ND 679-2289
I noticed in the PDF that it says actuation at 90 degree positions, which hopefully means that only one can be closed at a time. If more than one could be, then you could be trying to bump it up with the + and accidentally hit off.
Yaris = <3
Yeah, that would be counter productive :P
My R1 eats my Vitz!!
Drives: '07 Vitz Lifty, Stick Shift Join Date: May 2007
Wow, awesome job on the write-up man. I wish I could have done it, but I'm not that organized :) and flutie98...CTScott put together an LED module (that I still have yet to install...sorry scott) :( But I will get to it soon and do pics and a small write up on it so he can sell em to you guys and you can install them.
My Car Rules! |
#14 |
Learn to Relax
Drives: 2007, Meteorite, LB Join Date: Dec 2008
Thank you, Vince87 and CTScott. This is my next project.
#15 |
Yaris = <3
Woot! My clutch switch is in the shop today; picking it up tomorrow. I'll probably do this up on Sunday, as long as I can get the switch and resistors on Sunday.
#16 |
Learn to Relax
I couldn't find the resistors 290 and 340. Are those the correct values? They also had 1/4, 1/2 and 1 watt resistors. Which wattage?
#17 | |
You can use any value within these ranges: 216 to 264 ohms for one between resume and on/off 351 to 426 ohms for the one between set and resume 819 to 1001 ohms for the one between set and cancel For wattage, 1/8 or 1/4 watt is fine. |
#18 | |
Learn to Relax
| Cruise Control Available for 06/07 Yaris | TOYOTaejien | General Yaris / Vitz Discussion | 8 | 08-27-2010 12:58 PM |
| Cruise Control | chessclubloser | DIY / Maintenance / Service | 11 | 03-27-2010 11:59 AM |
