Old 05-05-2020, 12:39 AM   #1
TcBryan
TcBryan's Avatar
Drives: 2007 yaris sedan base
I have found several at the local pick your part yards.
TcBryan is offline   Reply With Quote
Old 05-05-2020, 12:42 AM   #2
TcBryan
TcBryan's Avatar
CT Scott, I will trade stalks for wire harness for cc.
Old 11-27-2020, 06:03 PM   #3
nowe_service
Drives: yaris 2018
Has anyone installed CCS on the Toyota Yaris 2018 facelift
nowe_service is offline   Reply With Quote
Old 11-27-2020, 10:46 PM   #4
yarisa07hatchi
Drives: yaris 07 hatchi
where can i get ecu wire for cruise and wiring harness for clutch switch help
yarisa07hatchi is offline   Reply With Quote
Old 11-27-2020, 10:47 PM   #5
yarisa07hatchi
where can i get firewall piece i lost it
Old 12-28-2020, 01:37 AM   #6
Kasbien
Kasbien's Avatar
Drives: 07 Sedan (AT)
So I read through the entire thread but didn't find a solution my issue (some similar cases but no resolution).
I have an 07 sedan, auto transmission, Canadian car. I went to perform this mod today, only to find that I have a factory wire (pin 40) at the ECM connection but no wire at the D3 connection under the steering wheel. No CC lights in the cluster either. Car has been dealer serviced since day 1.
Anyone else figured this one out?
EDIT:
Found the solution in another thread. The pin 40 wire seizes to exist after the firewall connection (AD4) on the drive side of the vehicle. Weird! See attached photo. Hope this helps someone out because it sure as hell gave me headache.
File Type: jpg DIY Cruise Control Wiring Issue Fix.jpg (132.7 KB, 70 views)
Kasbien is offline   Reply With Quote
Old 03-19-2010, 09:26 PM   #7
Originally Posted by weaver615 View Post
ok Scott I'm gonna try to rebuild the circuit and splice it back in. The 560 ohm 1/2w resistor with 5% CFR would be ok right? It would put me at 588 ohms almost at the middle of the scale but better than 714 ohms. Another thing I just noticed is the switches I bought Radioshack catalog #: 275-644 don't say whether they are NO or NC, Would these switches Radioshack catalog #: 275-1566, be better? I know they have to be NO switches, just wondering if that could be the problem I got NC instead of NO switches.
A 560 is probably too low. The 5% can go either way, so if you use a resistor close to either end, you really should check it with an ohm meter to verify what the actual value is. Being within the range is critical. If you are out of band, the ECM will not recognize the function.
The 275-644 switches are N.O., so they are fine.
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
