Holy crap YW is becoming a scary place to ask for advice.
Hilton, your link backs up everything I've said. There isn't a timetable on moisture getting in an unsealed container. It could happen the first month, or it could take 20 years. Ya you can get lucky a lot of the time and nothing will happen, but like I said, is ONE quart of oil worth the risk of rebuilding your engine? |
Half a Bubble Off Plumb
You're going to have to pour water in that bottle to have a problem with it. Oil is not something that just sucks moisture out of the air, and presumably you've had the cap on the bottle so it's only had the water vapor in the bottle. You're worrying far too much.
#3 | |
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
Never has. It's a nonissue.
Back when oil came in cardboard cans with metal ends that you punctured, everybody kept around open cans of oil for topping up. It was a good thing to keep a rag on top to keep dust out of the holes, but if one hadn't been covered you'd just wipe off the top of the can and pour it in. Oil stored that way worked fine. Over years of standing still, some oil components may gravitationally settle. Giving it a shake's a good idea. |
#5 | |
I was being sarcastic @ Supmet ![]() but I still like the old guy... |
| Synth Blend Oils | scape | DIY / Maintenance / Service | 7 | 07-12-2009 01:55 PM |
| Engine oil ddi not come out | hans_fh | DIY / Maintenance / Service | 18 | 01-23-2009 11:30 PM |
| Noob engine oil question. Do I HAVE to use 5w-20? (closed) | yarisugi | DIY / Maintenance / Service | 5 | 11-09-2008 05:34 AM |
| oil and oil filter question.. | marcus | DIY / Maintenance / Service | 27 | 07-11-2007 03:25 PM |
