![]() Drives: 2008 Toyota Yaris Join Date: Aug 2009
Freaky acceleration experience
Last night when I was driving my 2008 Yaris home late from work on a desolate road, all of a sudden I had absolutely NO exceleration power. The car runs so quiet that at first when I steered it over to the side of the road I thought it had died completely but, that wasn't the case. It was still running just no exceleration. I turned the key off and it re-started with no problem and then ran properly the rest of the way home (about another 8 miles). I went out and double checked the oil and coolant today and they are at required levels and clean. The car continues to start today and i pushed on the excelerator and it sounds fine. No noises or smells going on. However, the second I lost exceleration briefly last night the Check Engine light came on and is staying on.
I purchased gas at a Chevron station that I used a few times a couple of days ago and have noticed since then a feeling of poorer exceleration - it's not consistent - very irratic. I'm wondering if I could have gotten some bad gasoline?? Any responses would be appreciated. Thanks Last edited by echo_hrs; 08-29-2009 at 09:53 PM. |
It may be just a glitch in the ECU that may never happen again.
This is not unheard of. ......or it could just be bad gas as you suspect. |
![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Bayou Blue LB AT Join Date: Oct 2008
That happened to me at Sunday's autocross race. When I put an OBD II scanner on, it read that the CEL code was for a Cylinder #2 misfire. It's hard to tell what happened to your car with out an OBD II scanner. Essentially, the car went into limp mode, temporarily.
Try racing in limp mode!
aFe Intake | Blitz Supercharger | Megan Header | TRD Exhaust | NST Pulley Set TRD Shocks/Struts | Tanabe NF210 Springs | TRD Sway Bar | Motegi TRAKLITE wheels | Kuhmo Ecsta XS R1 Concepts slotted rotors | Carbotech 1521 brake pads | stainless steel brake lines | Seibon vented carbon fiber hood |
Drives: yw calls me douche and racist. Join Date: Aug 2007
Excited car?
"Stealth Runner"
you guys' humor is excellent...
I've had a similar experience before, bad gas too as far as I could tell, like the engine just stopped responding. Like LtNoogie said, only way to be sure what's going on is some kind of diagnostic code scanner :)
![]() ![]() ![]() ![]() ![]() Drives: yaris 08 sedan Join Date: Oct 2008
I had a similar problem where i had no throttle response and CEL came on,first time i just restarted the engine and it didnt happen again for a few weeks,after 2 months it was happening almost everyday and i got quite good at turning the engine off then back on whilst driving,finally took it to the dealer and he replaced a part of the wiring harness in the front of the engine and i've had no problem ever since.
Thanks for all the responses.
I drove the car to work today 16 miles each way. It starts fine and the Check Engine light actually didn't come on this morning when I first started it. I made a couple of stops on the way home and both times it started back up good for me. It runs like a top - quiet, smooth and good acceleration now. I guess I'll just see how it goes. It really freaked me out the other night when I lost the acceleration power - I'm 62, was alone, and it was dark and late with very little traffic. Scarey for a woman. I do have a cell phone but, was still scarey for me. I would still like to hear from any others that have had this happen. Especially, if someone actually knows what could have caused it. Seems like if it had been bad gas, it would have happened again, or be running roof and sputtering etc. I've gotten a hold of bad gas twice in my lifetime in two different cars and this really isn't acting the same. Thanks |
#9 | |
Thomas, wasnt there a TSB for the engine harness?
#11 | |
i remember a YW member posted a video of his lapping day at the track.. when he suddenly had no more throttle response and a CEL came on. He pulled over and restarted, everything worked just fine.
i'm surprise to hear it is happening to more than just 1 member. |
Half a Bubble Off Plumb
You need the stored trouble code(s) read. We can speculate a lot, but that would really narrow down the possibilities.
#14 |
Your mom goes to college
Drives: 08 Vitz Join Date: Oct 2008
Wow, weired I found this tread cause this happen to me last thursday night . I was driving on the freeway and the car just cut out , I pulled over and it started right up , then happended it like 2 minutes later . Hasn't happend to me before and hasn't happened since...
#15 |
Did you look around for UFOs?
#16 |
So far, so good. Just a reminder that my check engine light went off and is staying off.
I drove the car back and forth to work yesterday appx. 50 miles total - lots of stop and go driving - no problem. And, to church today - appx. 50 miles total - again lots of stop and go driving. Purrs like a kitten, runs smooth, kicks into passing gear smooth and great acceleration. I will definetly take it to the dealer if it happens again. Appreciate all the responses. |
#17 |
![]() ![]() ![]() Drives: 2008 Yaris Liftback Black Join Date: Oct 2008
I think bad gas could do this... mine sputters when i put low quality gas from el cheapo gasoline stations... so now I just try to stick with brand name gas even if it cost a little more.
#18 |
You can get watery or dirty gas at any station, "good brand" or otherwise. Stuff accumulates in the bottom of the station's tanks and gets stirred up in the gas when they fill it from the truck, so it's best not to pump gas for a while after the truck's come.
| My BestBuy Experience | nick.dollimount | DIY / Maintenance / Service | 11 | 07-27-2009 06:01 PM |
| Just installed Rostra cruise... My experience | cfiimei | DIY / Maintenance / Service | 7 | 01-13-2009 12:09 AM |
| Please Rate Your Experience | NonStopTuning | NonStopTuning | 4 | 10-22-2008 01:28 AM |
| This is my buying experience | yoyoche | New YARIS Purchase Forum | 9 | 08-13-2006 08:01 PM |
| My Yaris purchase experience.... | asa805 | New YARIS Purchase Forum | 21 | 07-09-2006 10:45 AM |
