Old 09-04-2009, 10:44 AM   #12
IsLNdbOi
IsLNdbOi's Avatar
Originally Posted by alvant View Post
Diameter of the stock exhaust outlet is 50mm, about 1.96"... hope this helps...
Thanks alvant. That's much smaller than the 2.25" inlet of the one I want. I hope the clamp can adjust to that size.
This one fits the HB perfectly. The measurements are found in the link. You can find the same one at Walmart for about $12.
http://www.jcwhitney.com/autoparts/I...D:100000186093
Thanks kimona. That's quite a bit longer than what I want though. It's 8" long vs. 4" for the one I linked to above.
does BACK-PRESSURE increase MPG vs straight thru... marcus Fuel Economy Forum 25 05-03-2009 09:23 PM
exhaust tip DJ_stone Cosmetic Modifications (Exterior/Interior) 1 01-20-2009 07:52 PM
Exhaust Tip Decision ruimond Performance Modifications 19 12-15-2008 12:49 AM
What aftermarket exhaust will fit the Yaris Sedan? dngz Performance Modifications 2 10-02-2006 01:41 PM
can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. fantabulousbaby Cosmetic Modifications (Exterior/Interior) 22 08-29-2006 01:13 PM
