Old 10-10-2009, 05:36 PM   #1
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
Originally Posted by camelll View Post
Yeah I found it amusing as well.
You should really quote who you are talking about. I am assuming you are saying this for illusionx?
Again, you should quote who you are posting about, who is giving out wrong information? Illusionx is or was the the only one on here that thinks that the compressor is engaged 100 percent of the time. There have been several post to explain the opposite since that post.
True, quotes are helpful, but mine wasn't directed at anyone, other than simply stating some facts relevant to the thread.
I will quote more in the future.
Old 10-15-2009, 09:06 PM   #2
LittleRed
LittleRed
Drives: 2008 Yaris Hatchback 5spd
I put in a AEM cold-air intake and my car no longer bogs down with the A/C on...apparently the engine is starved of air under stress...its really easy putting it in....well worth the $150... i also use fuel system cleaners in it on a regular basis and use 91 octane gas..its really quick now
LittleRed is offline   Reply With Quote
Old 08-05-2010, 10:13 PM   #3
NH3R717
Drives: Yaris 3dr Hatch, White
22 hp is a ridiculous amount of power for a car a/c. 22 hp = about 16kw. Your home A/C might pull 2-3kw. hp and kw = power the same exact thing but different units.
NH3R717 is offline   Reply With Quote
Old 08-06-2010, 08:38 PM   #4
krolos
Drives: 2008 yaris sedan
I have owned V8 trucks, and other small 4 cyl. cars with Ac.
And I can tell you my Yaris has been by far the most sufficient with AC on, the gas mileage changes very little, if at all, yes it does bog the engine down a little,
but for a 1.5 I would say it is pretty good, and really not a whole lot.
33,000 miles on 2008 sedan, and no problems.
krolos is offline   Reply With Quote
Old 08-07-2010, 11:46 AM   #5
Yarisduder
Yarisduder's Avatar
Drives: 2007 4dr Sedan Silver Streak
+1 000 000 000
That's what I wanted to say!
Yarisduder is offline   Reply With Quote
Old 09-09-2009, 09:54 PM   #6
IllusionX
Drives: 07 Yaris Sedan Aero
The AC compressor has a clutch that engages and disengages that is what they are talking about cycling, it engages as needed.
The AC compressor stays engaged, until the AC is turned off....
Old 09-10-2009, 01:52 AM   #7
ddongbap
This thread is going to be another one of those threads where people just spout out information that they've heard.
I've dyno'd the car, with and without the AC on. 3 whp difference.
Old 09-11-2009, 08:40 PM   #8
tazrulesny
Drives: 08 Toyota Yaris Sedan
Don't take my word for it, go turn your ac on then actually watch the compressor, you will see and hear when it engages and when it disengages. Just because your ac light on the knob is on does not mean the compressor clutch is engaged.
Hahahahah that cracked me the hell up. Guess when my head lights are on doesn't mean my car engine is still running huh?
tazrulesny is offline   Reply With Quote
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 09:17 PM
