Old 09-05-2009, 12:18 AM   #1
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
I couldn't find the resistors 290 and 340. Are those the correct values? They also had 1/4, 1/2 and 1 watt resistors. Which wattage?
Old 09-05-2009, 12:28 AM   #2
It's actually 240 and 390.
You can use any value within these ranges:
216 to 264 ohms for one between resume and on/off
351 to 426 ohms for the one between set and resume
819 to 1001 ohms for the one between set and cancel
For wattage, 1/8 or 1/4 watt is fine.
Old 09-05-2009, 11:05 AM   #3
yaris-me
Learn to Relax
Thanks!
Old 06-29-2011, 12:45 PM   #4
PROX4x4
1.5 or 2.5 both=0-60 in 8
Drives: 08 Toyota Yaris
I wonder if this switch would work for the on/off & Set setting for this type of cruise control setup?
http://cgi.ebay.com/ebaymotors/CARLI...Q5fAccessories
PROX4x4 is offline   Reply With Quote
Old 06-29-2011, 12:53 PM   #5
The switches need to be momentary. That on is ON/OFF/Momentary, so it would be OK in one direction, but not the other. You'd want Momentary/Off/Momentary.
Old 06-29-2011, 01:08 PM   #6
PROX4x4
Been looking around to see if I can make something funky using your lighting module and resistors set up with below switches, but I guess nothing beats the stock CC setup.
http://cgi.ebay.com/1-Stainless-Mome...item43a7fb8cea
Your innovations clears the way to personal styling of Yarises in this world :D
Thanks again!
Old 06-29-2011, 01:53 PM   #7
Thanks again!
Those would work, and the lighting is isolated from the switching, so that's good as well. For $9 each though the cost for 4 is the same as what I sell the stalks for.
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
