Old 09-10-2009, 01:51 AM   #1
eocintron
Joder... Es un Toyota!
eocintron's Avatar
Drives: '09 Polar White 5-Door HB
What's the right way to paint hubcaps?
I want to paint my grey hubcaps black til I save up enough for some new wheels, so I was wondering, do I just sand them a little, then primer and then paint...? If not, what's the most "professional" way of doing it?
eocintron is offline   Reply With Quote
Old 09-10-2009, 03:01 AM   #2
I'd sand them down stepping up(?) in grit, meaning going from coarse to really fine (not directly of course), then wash them up really good with some dish wash soap. Primer, then base coat about an hour later. Add more layers as you wish at the recommended intervals on the can. Then after letting it dry, shoot it with some clear coat.
Old 10-07-2009, 08:38 PM   #3
SaerinRhoe
'09 Yaris
Drives: '09 Yaris
I'd like to do this as well and I've had questions about what grit of sandpaper to use. I started to sand one of the wheelcovers but stopped after getting one section done and I thought I'd check around here and ask.
I started sanding with 150 grit sandpaper and that seemed like it was gouging the plastic a little. After using that to get the first section done, I went back over it with 80 grit and that removed the deeper marks but here's my question.
Do I need to use a lower grit paper after the 80 to get better results or am I just wasting precious calories at that point?
Thanks,
S.R.
2009 Yaris 3-Door Liftback MT Black Sand Pearl
SaerinRhoe is offline   Reply With Quote
Old 10-07-2009, 08:39 PM   #4
AND189
Drives: 2
mate i gave them a lit sand 1200 grit hit them wis wax and grease remover don't touch after applying then sprayed them take your time do it in a dry/warm place away from dust for best outcome
AND189 is offline   Reply With Quote
Old 10-07-2009, 08:44 PM   #5
AND189
Drives: 2
yeh guys that grit is too rough you need 800 grit some thing to just take the shine off thats all
Old 10-07-2009, 11:05 PM   #6
06silveryaris
Drives: 2006 yaris
You can just use a scuff pad for the sanding
06silveryaris is offline   Reply With Quote
Old 10-08-2009, 11:39 AM   #7
eocintron
eocintron's Avatar
Sweet... Thanks guys. I'll be painting them in the next couple of weeks, and I'll be sure to post some pics so u can see the results!
Old 10-08-2009, 02:27 PM   #8
tomato
tomato's Avatar
Thanks! Can you post "before, during, after " ? :)
well, if you want
Old 10-08-2009, 02:31 PM   #9
sand to scuff surface
clean
primer
paint
clear
Old 10-08-2009, 11:33 PM   #10
SaerinRhoe
'09 Yaris
Drives: '09 Yaris
So I guess I'm +1 on the overkill then :)
Thanks for the info.
S.R.
Old 10-09-2009, 12:13 AM   #11
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
S.R.
At least you learned what 120 grit will do to a surface
Get some plastic filler from a hobby shop and fill in those gouges before sanding and painting.
Old 10-09-2009, 07:44 AM   #12
AND189
Drives: 2
dont tell my you guys are still clipping the gutter :P lol
Old 10-09-2009, 09:35 PM   #13
eocintron
eocintron's Avatar
Thumbs up
well, if you want
Sure!
Old 10-10-2009, 10:41 PM   #14
PlaidBear
Grizzly Yaris Owner
PlaidBear's Avatar
Drives: Blue Yaris 3 Door Hatch
I actually just did this and here is what was successful for me.
Remove Hubcaps
Wash thoroughly with dish soap
Remove the Toyota emblems if you want them to remain chrome
Scuff all of the shine off of the caps with grey scotch brite
Wash again with dish soap
Once dry, dust them with a tack cloth without touching the surface to be painted with you hands
Put a light coat of Adhesion Promoter(I use this when painting any plastic or Aluminum)
Prime
Paint
Clear coat if necessary
Glue the emblems back on (I used a high strength Resin glue)
Done
PlaidBear is offline   Reply With Quote
Old 10-12-2009, 01:50 PM   #15
tomato
tomato's Avatar
what kind of paint do you use? Anything?
Old 10-12-2009, 03:49 PM   #16
Saskatchewan17
MS3 Driver
Saskatchewan17's Avatar
Drives: 2008 Mazdaspeed3
Prep prep prep prep and more prep!
Did I say prep?
That's the most important thing by far! Getting a nice clean surface so you can lay down paint nice and even.
08TrueRedMazdaspeed3
-PERFORMANCE:
-CP-E SRI - PG TURBO INLET PIPE - GREDDY TYPE S - TRZ REAR MOTOR MOUNT-
-OTHER:
-STRIPES - EXHAUST RESOS DELETED - BLACKED OUT BADGES - TOWPLATE - HD LIP -
- PROSPORT BOOST GAUGE/VENTPOD - STREET UNIT SHIFTER BUSHINGS - TINTED REFLECTORS/SIDE MARKERS/3RD BRAKE LIGHT - SIDE MOLDINGS REMOVED -
Saskatchewan17 is offline   Reply With Quote
Old 10-12-2009, 07:45 PM   #17
*MAD DOG*
*MAD DOG*'s Avatar
Don't do it. Buy rims.
Old 11-10-2009, 09:16 AM   #18
eocintron
eocintron's Avatar
Ok, so I started the process, but it's been raining like hell in Puerto Rico, so, that slowed me down. I'll post pics up to what I've done, which is sanding and applying primer.
Before
During (after sanding with 3M 1000 and 600 in that order)
During (after primer)
During (all hubcaps with primer)
If the weather decides to cooperate with me, I'll soon post pics of the job finished. Its coming along pretty well I'd say...
DIY: Painting Engine Cover frownonfun DIY / Maintenance / Service 12 12-01-2013 12:07 AM
New 2007 Paint Condition Pavel Olavich DIY / Maintenance / Service 16 09-13-2009 05:14 PM
Touch Up Paint for Hubcaps nwdixieboy Wash, Wax, Detailing, Exterior Repairs 4 04-05-2009 03:49 PM
Questions about interior color and exterior paint wiirenet General Yaris / Vitz Discussion 5 03-01-2009 07:28 PM
should i paint my hubcaps bronze? (photoshopped picture included) BrazdonW Photo-Video-Media Gallery 21 06-25-2007 03:18 AM
