Old 04-03-2010, 08:55 PM   #1
swidd
Drives: Yaris HB
Thanks Palmer. That worked. $1.99 to radioshack for the switch, soldered it. Actually didn't attach it to the parking brake, just made a very improvised ground, connected that to the switch, and, like you said, I have to toggle the switch on and off to put it on video-and-nav mode. Thanks!
swidd is offline   Reply With Quote
Old 07-04-2010, 10:34 PM   #2
Revsson
Slick,
I used part of your DIY for installing power wires into my car. I forgot about removing
the plastic piece above the battery, as that would have been very convenient. I also
did not cut the carpet, but removed some bracket up to the top right, so I could pull
the carpet back to route the wires. However, in my impatience, I ended up tearing
the carpet or insulation , but at least it is not where it can be seen.
I had a heck of a time getting both power and ground wires under the trim
piece around the rear seatbelt. I have the sliding rear seats, so did not
want any wires exposed back there.
I bought a grommet from Napa, but can't find the exact model number.
I think it was for a 3/4" hole. We had a hard time getting that on the
firewall, but ended up lowering the computer to get our hands in there.
So, now I have power and ground cables in the rear by the spare tire, for
future radio amp installation.
Old 07-05-2010, 08:35 PM   #3
cfeng
Drives: Yaris 2010 Liftback
have you ever ran new speakers without an amp? i'm using 100w polk audio component speakers now. the issue is that my head unit goes blank or ejects an mp3 cd on its own randomly. i think i might be drawing too much power from the stock head unit. any ideas why this happens?
cfeng is offline   Reply With Quote
Old 07-07-2010, 06:08 AM   #4
Falconeer
Bayou Blue Pearl.
Drives: Yaris 5D Liftback Full Options
I am running 260W Pioneers, nothing like this happens to my system. Yeah and not using an amp at the moment. Only for the sub which draws signal from the rear speakers via a LOC.
I usually listen near peak volume of head unit.
BOSCH 8000k HID Headlights, BOSCH 8000k HID Fog Lights. BOSCH Horn. 30% tint all round. 70% Tint mirror-finish tint on front wind shield. TRD Leather Shift Knob, Leather Steering Wheel, TRD Emblem. Height adjustable driver's seat is cool! and... That great armrest from ebay
Falconeer is offline   Reply With Quote
Old 07-07-2010, 11:55 AM   #5
Slick
Slick's Avatar
Drives: '09 3-Dr
Send a message via MSN to Slick
@revsson Im glad it worked out :) The hole in the carpet is more for convenience. It is possible, like u said, to move the carpet out of the way, but a small slit is just quicker. And since there is already carpet on top of it, it's hidden pretty well.
And yes, hiding the power wire is a pain. Lol
Good luck to everyone and I'm glad I could contribute.
In a world... where things squeak, wont fit,start to bleed, or are just plain hard to do.... ArmorAll will fix that
Slick is offline   Reply With Quote
Old 12-02-2010, 09:14 PM   #6
Clintondmb
Drives: '08 3DrLB.
Many thanks for this DIY. if it were not for this I would have done the old feed the power wire through the fender into the door trick. but this looks 100% pro everything is hidden. I am going to post photos of my whole system in a week or two when I find time to take some pictures.
Clintondmb is offline   Reply With Quote
Old 02-10-2011, 12:31 AM   #7
Nodrog
Nodrog's Avatar
Send a message via AIM to Nodrog
do it?
Did you get this done, Clinton? Do you have pics?
If it aint fixed, don't broke it.
Nodrog is offline   Reply With Quote
Old 02-10-2011, 12:30 AM   #8
Nodrog
Nodrog's Avatar
Slick,
how did you attach the fuse holder? It looks like it's screwed to a hose clamp?
Old 10-12-2011, 07:49 AM   #9
Gavilaso
Drives: Yaris Hatchback 2007
Hi i would like to know if this work on a 2006/7 hatcback???? is the grommet on all yaris???? I need to install a HAM radio to mine!!! any help will be appreciate!
Gavilaso is offline   Reply With Quote
Old 07-03-2012, 11:27 PM   #10
razingman
Drives: 2007 ls liftback 5 door manual
dumb question but why the fuse last?
razingman is offline   Reply With Quote
Old 11-10-2021, 04:01 PM   #11
croustian68
Drives: Yaris LE 5dr 2016 AT Blue
i want the pdf please
croustian68 is offline   Reply With Quote
Old 12-20-2021, 08:58 AM   #12
David90
Drives: Mazda
Mate, this is good stuff!!! Have you ever thought about https://www.youtube.com/
Really appreciate this
David90 is offline   Reply With Quote
DIY amp wire running and radio trim removal Slick DIY / Maintenance / Service 0 09-10-2009 08:00 PM
