Old 09-11-2009, 12:48 PM   #1
Rick Flynn
Drives: 2007 Yaris
That was very thoughtful and, yes, that tube was actually okay, but it's tank above that needs cleaning, and that's tricky. By the way, the dealer admits it's a design problem, but they're not taking responsibility for it. Odd, that Toyota would let something like this pass without fixing it.
Thank you!
Rick
Rick Flynn is offline   Reply With Quote
Old 10-03-2009, 12:19 PM   #2
tenaz
Drives: 2007
Arrow Air Conditioner Noise & Leak
To all :
I found this link : http://townhall-talk.edmunds.com/direct/view/.f0f88fe/0
I put my notes as I did on this forum.
U.S Yaris 2006 -? has this A/C issue believe me is a design problem.
At least I found 3 people with the same issue I had.
For Toyota is easy to say I take a complaint and we look into and done nothing.
For further assistance contact http://www.consumerlawcenter.com/
Regards
Tenaz
tenaz is offline   Reply With Quote
Old 11-01-2009, 04:18 PM   #3
Rick Flynn
Drives: 2007 Yaris
Fixed it
Thank you!
Rick
The tank did not drain when my mechanic checked the hose and the local Toyota dealer (Fremont CA) wanted 80-150 to diagnose the problem which I'd already had diagnosed. Wondering what to do, I finally had a moment of inspiration--not bad for a clutz like me--and I thought, "Why not remove the drain hose and stick a clothes hanger up the hole"? Well, it worked. Water poured out of the tank, and the leak has not returned for two months.
R
Air Conditioner kick-in?? churp General Yaris / Vitz Discussion 5 05-26-2007 08:43 AM
Air Conditioner Noise Cathy General Yaris / Vitz Discussion 16 05-08-2007 02:08 AM
Air Flow switch problem aucorium DIY / Maintenance / Service 5 01-15-2007 04:54 PM
1.3 Ltr Yaris Air Filter mods aucorium Performance Modifications 9 08-18-2006 08:32 AM
