Old 09-13-2009, 10:37 AM   #1
opt101
Drives: 2007 Toyota Yaris 2dr
I just need the simple one in the diagram, on/off and set as I drive 55 mph straight and there really isn't any need for the 4 button set up. So if I get the value pack, it will have the 390 but will it have the 240 ohm that’s depicted in the picture, where do I get that one,
opt101 is offline   Reply With Quote
Old 09-13-2009, 11:18 AM   #2
If you are doing the two switch method, then you really just need one resistor in the 567-693 ohm range. The Value pack includes a 680 ohm resistor which would be perfect.
Out of curiosity, where in CT are you? I am in Southbury and have an inventory of literally thousands of resistors.
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
