Old 09-13-2009, 12:31 PM   #1
opt101
Drives: 2007 Toyota Yaris 2dr
CTScott, would these resistors work?
Radio shack part # 271-1117
680 ohm 1/2W 5% Carbon Film Resistor pk/5
or do I need the ones in the value pack,
also will these switches work.
Radio shack part # 275-1571
SPST 0.5-Amp Momentary Switch (2-Pack)
One red and one black. Rated 0.5 amps at 125VAC and mounts in a 3/8" hole.
or are these better
Radio shack part # 275-609
3A 250VAC momentary switches normally open
And my last question, if the vehicle goes for service, I assume all this would have to be pulled out as it would most likley void the warranty? Thanks in advance.
opt101 is offline   Reply With Quote
Old 09-13-2009, 01:21 PM   #2
or are these better
680 Ohms is fine. The 1/2 watt resistors are physically larger, but are fine.
For the switches either is fine. I used 275-644, but really any normally open momentary switch is fine. You are switching 0 current, so the rating really doesn't matter.
As far as warranty goes; Unless the dealer can prove that your DIY cruise control actually caused something to fail, they can't say that you voided the warranty.
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
