ellenbetty
Drives: 2 2007 Yaris 3 door liftback Join Date: Nov 2008
I got the fog lamps to work. I had to follow directions, cut the yellow wire in the steering column, and use connectors to make a connection.
At least one of the fog lamps bulbs lit, (I did not feel like checking the other, too tired), and the dash light for fog lamps on lit up. But I do have a problem. The switch to the fog lamps remains lit even if the key is out of the switch to the ignition. Makes me nervous. Does any one have a idea of how long will it take for that light in the switch to drain my battery so much that I will not be able to start my Yaris? Since I do not wish to find out the hard way what impact that light in the switch has on my battery, I unplugged the switch. |
| HELP!!! I went back to the service center yesterday for the 7th time in 2 months! | Meldav86 | General Yaris / Vitz Discussion | 27 | 08-21-2007 09:04 PM |
| DIY - HID Retrofit | Violin | DIY / Maintenance / Service | 57 | 06-11-2007 06:17 PM |
| Did you order fog lamps? | Driver | New YARIS Purchase Forum | 27 | 11-29-2006 06:27 PM |
| Where to find Yellow capsules for fog lamps? | W.A.S.P | Cosmetic Modifications (Exterior/Interior) | 0 | 11-26-2006 01:01 AM |
