Old 09-13-2009, 07:24 PM   #11
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Originally Posted by ellenbetty View Post
I got the fog lamps to work. I had to follow directions, cut the yellow wire in the steering column, and use connectors to make a connection. At least one of the fog lamps bulbs lit, (I did not feel like checking the other, too tired), and the dash light for fog lamps on lit up. But I do have a problem. The switch to the fog lamps remains lit even if the key is out of the switch to the ignition. Makes me nervous.
Does any one have a idea of how long will it take for that light in the switch to drain my battery so much that I will not be able to start my Yaris?
Since I do not wish to find out the hard way what impact that light in the switch has on my battery, I unplugged the switch.
i think the simple answer is to swap the 2 wires around The Red and Yellow wire on your switch .
does your switch stay lite up even if it is turned off and park lights off .
HELP!!! I went back to the service center yesterday for the 7th time in 2 months! Meldav86 General Yaris / Vitz Discussion 27 08-21-2007 09:04 PM
DIY - HID Retrofit Violin DIY / Maintenance / Service 57 06-11-2007 06:17 PM
Did you order fog lamps? Driver New YARIS Purchase Forum 27 11-29-2006 06:27 PM
Where to find Yellow capsules for fog lamps? W.A.S.P Cosmetic Modifications (Exterior/Interior) 0 11-26-2006 01:01 AM
