I love my Yaris!
Drives: White Yaris Liftback 2 Dr. AT Join Date: Sep 2006
Liftback Rear speaker installation tutorial (Pics)
Well, I decided to upgrade my rear speakers since I got a couple of Sony for the front and needed to match the power but add a little more bass.
First, look at the tabs' diagram so you will know what you will encounter when pulling the panel away from the car's body. You don' need to remove the rear seat or the weatherproof trim to pull the panel apart, just use patience, common sense and have a beer next to you and the process will be painless. Keep this in mind, in the middle of the panel there is a pressure tab blue in color that is not pictured in the diagram; be careful not to break it. Place one hand on the inside of the panel to feel the tabs that you can't see; don't just yank the panel off. Once the panel is off you will see that there is a lot of room for even a sub woofer in that space, you can use several sizes of speakers on the stock location, as long as you have the appropriate brackets, you might have to drill new holes for some applications. I used the brackets provided with my Alpine speakers and had to drill three new holes for the new brackets. Since the stock speakers have a special connector you might have to cut the wires. No biggie; once you see what the stock speakers are made of you will know you'll not use them again! Do this process in reverse to reinstall the panel and there you go! Enjoy the new sound!!!! |
Look mum no stars!!
Very nice
Question : do u get rattling sounds from the plastic panel when the bass is up?....
#3 | |
I love my Yaris!
Look mum no stars!!
I think i have to dynamat my plastic panels........
My speakers are fully secure with no loose gaps or loose for the matter. Damn plastic panel rattles for some odd reason. Thanks!
mine rattle hardcore. but after looking at different dynamat types i find b-quiet to be a good cheaper substitute. im just too lazy to install it.
#6 | |
Look mum no stars!!
I have this silver ahesive version......best sound deadening material i ever baught!....
I drive a yarrrris
Drives: 07 Sedan Polar White Join Date: Sep 2006
very nice
![]() Docotrs say all the drikning has mesesd up my seplilng and radieng will work for parts |
![]() Drives: 2007 yaris hatchback Join Date: Mar 2007
where did you get that diagram?
and how much space is back there depthwise. I'm thinking of going with these
http://www.cardomain.com/item/IDSID8V3D2 |
swappin cogs
excellent post. thanks
Speed+Metal=Life
HAH those are the same exact speakers i'm putting in my front doors today.
Drives: 07 Yaris CE, Bayou Blue Join Date: Apr 2007
I have searched everywhere but no answer to be found.
On a Base Model CE 3dr...did Toyota run the wires towards the rear speakers even though there are only front speakers, or will I have to run some wires to install rear speakers ?? Nice Post by the way, it'll come in handy when I decide to do my install. Thanx |
![]() ![]() ![]() ![]() ![]() Drives: 2007 Bayou Blue!!!!!!! Join Date: Nov 2006
wire are there.
Drives: 2008 Yaris hatchback silver Join Date: Jul 2009
Thanks for the info on how to get at those rear speakers. after 1.5 years of constant.... I mean CONSTANT, head unit (ONLY) power ( 450x4 only running the 12" and the alpine components up front). the stock speakers my boys at Pacific Stereo (Woodland Hills, CA) left alone in the rear finally started chirping horribly!!! I NEED 2 disconnect them B4 I even leave my friends house..... THANK YOU SO MUCH!!!! If it's too loud...... UR 2 OLD!!!
Thanks alot W.A.S.P. Just installed some speakers thats been sitting in my room for some time thanks to your guide. All i need now is a rivet gun and maybe a drill to mount them.
You can use sheet metal screws or even nuts and bolts too.
I bought Pioneer 4 ways from Crutchfield and they came with an adapter patch cable eliminating the need to cut wires.
![]() ![]() ![]() ![]() Drives: soarer Join Date: Feb 2011
Nice tutorial. Thanks, WASP !
Free Mustache Rides
This should help. Thanks.
^ Did you mean front speakers?
| When will the Yaris hit the showrooms at dealers? | Petrolhead | New YARIS Purchase Forum | 181 | 11-28-2011 08:03 AM |
| How to remove rear speaker panel on a Liftback? | W.A.S.P | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 11-25-2006 02:45 AM |
| -- Liftback Rear Speaker Removal? -- | rarmogan | In Car Entertainment + Electronics (audio / video / alarm) | 2 | 09-25-2006 04:48 PM |
