![]() Drives: Toyota Yaris Join Date: Apr 2007
well darn, I feel like an idiot now. Thanks CTScott
#3 | |
EDIT: Just seated the terminal correctly, thanks again! Last edited by flutie98; 09-15-2009 at 06:39 PM. |
![]() Drives: 2009 Yaris Sedan Join Date: Aug 2009
Just in case you are still curious, I found examples of locking mechanisms in the wiring diagram manual, page 14 through 16. Page 14 on the bottom left has some nice figures of a terminal with the "terminal retainer" both in the lock position and the "temporary" lock position, which is where I think a small piece of the terminal contacts the back of the retainer and holds it in place, but not as firmly as when you put the retainer in the lock position. There doesn't seem to be an example of a connector just like A21, but in the last figure on page 16 the connector on the left seems to have a somewhat similar retainer. Also, the third figure down on page 15 shows a terminal inserted into a connector with the waterproofing sleeve on it.
![]() Drives: 2007 2DR Yaris Join Date: May 2009
I just received my insulated wire from trdsparks... I will update the DIY this week end so that nobody breaks his A21 connector while trying to fit it... Thanks again to CTScott for figuring this one out (what would we do without you?) !
![]() Drives: 07 Yaris Join Date: Oct 2009
Stupid question
From reading the posts in this thread, it appears as though this does indeed work however I'm curious why the Rostra kit has is so complex in comparison?
I mean really, if it was just as easy as running one wire through the firewall why would they bother with all of the other ones? Is it that the Rostra one supports many models & years and this DIY trick is only for the 07 and 08? Also, I'm not sure if anyone answered this already, but would there be any reason I couldn't purchase an OEM cruise stalk and use the wires from this with this method? If it's safe and works then I'd rather spend $25 on the OEM stalk and a couple of bucks on some wire then $250-500 for an aftermarket kit. Thanks |
#7 | |
![]() ![]() ![]() Drives: 08 Sedan Join Date: Oct 2008
Hey guys and CTScott..
I assume based on the interchangeable parts that this kit from the CruiseControl store will fully work with our Yaris which is for the 08 Corolla?... The kit includes the stalk and wire harness? I know it is expensive, but since it has the cutting tool to cut the hole in the trim for the stalk to go through I am considering it.. http://www.cruisecontrolstore.com/ez...3/250-1768%20C P.S... The switch to turn on the cruise control on the stalk, it is a mechanical switch to where it stays in when turned on, or a digital switch to where when pressed, it sends the signal to the ECU to which turns on the dash indicator?... Since I don’t have the dash indicator, I would rely on the switch to let me know if the cruise is on or off thanks guys! |
#9 | |
Now that is crazy expensive. You can buy the lower cover with the hole already in it for about $15 (part number 45184-52130-B0) and an ebay stalk for well under $50. As for the indicator, the switch is a momentary input to the ECM, so on 07-08's there is no indicator. I designed a circuit using a small microprocessor to see the button press and be able to distinguish between the on/off and the other buttons being pressed. Nickjhort installed and is using my prototype one. Cruz_gsr contacted me this week about getting one made, so I built some production ones and have been meaning to post a thread with them for sale. Below is a picture of the module. There is a panel mount blue LED for the indicator (that just requires a 1/4" hole). Two of the three wires are connected to the stalk (or switches for the full DIY version) and the third is connected to the ignition switched wire on the keyswitch. The modules are $25 shipped to the US and $30 shipped to Canada. CC Indicator Module.jpg CC Indicator.jpg |
#10 | |
Dude.. You DA MAN!!!!
| Cruise Control Available for 06/07 Yaris | TOYOTaejien | General Yaris / Vitz Discussion | 8 | 08-27-2010 12:58 PM |
| Cruise Control | chessclubloser | DIY / Maintenance / Service | 11 | 03-27-2010 11:59 AM |
