![]() ![]() Drives: 2007 Yaris Sedan Join Date: Nov 2008
Oil Plug do you prefer Ratchet or Box end wrench?
I am doing all the service on our Yaris these days to save cash. I am just paranoid about stripping the oil plug. Which do you think is easier to control and less likely to strip a ratchet or box end?
hopefully it's not so tight that you need anything more than a combination wrench to take it off. either/or will work. even a 9/16"
I use a ratchet to get it started, then a box wrench so I dont soak my arm in oil
When i do my own oil I prefer a ratchet but lately i am curious about the Fumoto Valve system of changing oil.
http://www.fumoto.com.au/ |
that's really bulky and oddly valved.
there are better options out there. brb i'll find one edit: http://horsepowerperformance.com/i-1...ly-torque.html Aeroquip is good stuff.
The Fumoto wouldn't be that bad on the Yaris considering where the dran plus is on the side of the pan, but I would hate to try it on my Tacoma that sticks straight down. The Aeroquip stuff looks nice
Ehhh I think I may just go back to letting the dealer do the service. I am getting so old and Lazy LOL
Last couple of years i've been getting my mechanic to change the oil.he charges $60 considering the synthetic oil up here is close to $40 and a dealer filter is $10 its worth the extra $10,especially in winter.
![]() ![]() Drives: 2006 Mazda3 Sedan Join Date: Jun 2007
Get a torque wrench and a socket. A decent beam-type wrench will run you about $20, and you'll never have to worry about stripping out the drain plug again.
the amount of torque required to strip those M14 (or M12) threads would be in the neighborhood of 200lb/ft. i highly doubt that a person could exert that kind of force lying down under their car with a box end wrench.
torque wrench is overkill, just get the plug "tight"
#11 | |
It cost me about 45 bucks at the dealer for an oil change and tire rotation and they fill up my washer fluid. Combined with the fact I don't have to drag out my drain pan, wrench, ramps ect. it is sounding like a better and better deal. |
keep in mind that they're putting recycled oil in your car. your $45 goes toward labor mostly.
#13 | |
Crazy Oil Sniffer
Drives: MM 09 Yaris 5 Dr LB "Click" Join Date: May 2009
Fumoto
The Aeroquip that Tamago posted though looks like the ticket for a Yaris-I just might have to order one of those. Tamago your commission check is in the mail, I'm sure! R2 |
Crazy Oil Sniffer
Oh, I forgot to mention that for the first removal of the drain plug I recommend you use a 6 pt socket. Mine was really anchored in there (the filter was also ridiculously tight). After that if you don't crank on it putting it back in a box end would be fine IMO.
R2 |
dealers buy oil in bulk, from their local oil distributor. it is usually recycled. if you personally see the tech open 4 bottles of oil and put them in your car, then i am wrong. but if they use an oil delivery gun it's most likely recycled oil.
Oh, yeah I took my Tacoma in for service earlier today actually. I watched the tech walk to the parts counter and the guy give him a Toyota Filter and Toyota brand oil.
#18 | |
![]() ![]() ![]() ![]() Drives: 2006 yaris Join Date: Oct 2008
you can get 5 qts dino and a decent filter at any chain like pepboys for $15 |
| Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 07:18 PM |
| DIY: CHANGE MANUAL TRANNY OIL | ttufrosty | DIY / Maintenance / Service | 157 | 09-07-2018 01:43 PM |
| Word Association | Black Yaris | Off-topic / Other Cars / Everything else Discussions | 7373 | 10-04-2011 10:43 PM |
