Old 09-17-2009, 10:35 AM   #1
RedRide
RedRide's Avatar
As the problem is, not enough of the hole is revealed to insert the pin, the soulution was to taper the end of the pin with a file to get it started.
However, this did not work and I still can't get it installed.
I might wind up modifying the SS with my dremel.
BTW, the cause if this is, athough the SS is a precision machined part, the shift arm and pin isn't and can vary is size sometimes.
Old 09-18-2009, 10:44 PM   #2
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Are you 100% sure on that You and me seem to be the only people with this issue and we both have the piggies kit.
Old 09-19-2009, 02:10 AM   #3
toast
Drives: 2007 LB
I had the same problem too. Took a couple of swipes with the dremel on the piggy and all was well. I thought it was strange but figured I bought cheap and had to throw in some of my labor to make it work. Been running it since feb '09 with no problems since install.
toast is offline   Reply With Quote
Back to school sale Short shifter, Shift Knob, EVERYTHING is on sale! TWM Performance TWM Performance 13 09-29-2009 10:55 AM
TWM Performance weighted shift knobs on sale! TWM Performance TWM Performance 5 06-30-2009 09:58 AM
NST NonStopTuning Short Shift Kits NonStopTuning NonStopTuning 2 11-11-2008 07:39 PM
October sale on TWM Performance shift knobs! TWM Performance TWM Performance 1 10-31-2008 05:01 PM
