Old 09-17-2009, 12:23 PM   #1
GnomeBody
AD&D Dork
GnomeBody's Avatar
Drives: 07Liftback/07sedanS
Good Review! I just received my Megan coilovers and plan to do the install this weekend. Hopefully I dont run into any huge problems.
Mods: K&N filter, Megan Coilovers, Ultra Racing 19mm rear sway bar, Sun tachometer, Window Tint.
GnomeBody is offline   Reply With Quote
Old 09-17-2009, 04:57 PM   #2
markitect
Drives: Yaris
Good luck on your install!
While your at it would you mind telling me what pieces you use off the original suspension. I'm buying "the barber"s and I'm thinking about getting new parts that are reused so they are a "easy swap" as I will probably only run them in the summer.
Heck if your feeling ambitious do a Megan specific DIY.
markitect is offline   Reply With Quote
Old 09-18-2009, 11:00 AM   #3
GnomeBody
AD&D Dork
GnomeBody's Avatar
I'll try and make a list and snap some pic's of the reused parts.
Mojo Jojo from the microimage forums said "You'll need to re-use the stock strut bearing in front. You remove it and press it onto the Megan strut, tighten with stock nut, then put the stock rubber "donut" on. For the rear it's just the dust cover and bumpstop."
as for the DIY, I'll see what I can do.
