Old 09-19-2009, 12:02 AM   #1
Nachtmensch
Drives: 02 Toyota MRS
http://www.yarisworld.com/forums/sho...og+lamp+wiring
btw, this is Kevin
Nachtmensch is offline   Reply With Quote
Old 09-19-2009, 12:15 AM   #2
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
if you emailed me i could have sent you the instructions .
the red wire with white plug plugs into the light harness
and then into the factory wiring inside the fuse box
under the bonnet .
Old 09-19-2009, 12:41 AM   #3
kuyachris84
kuyachris84's Avatar
Drives: 2008 Yaris Liftback Black
under the bonnet .
can u take a picture of what u mean?
if its not too much too ask. .. pls ^^
2008 YARIS/VITZ LIFTBACK - BLACK SAND PEARL
Representing The Midwest!
http://www.cardomain.com/ride/3132598
kuyachris84 is offline   Reply With Quote
Old 09-19-2009, 01:17 AM   #4
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Take the Red wires with the white plug (as photo'd above )
jion it to the red wire comeing from the fog lights , then plug those 2 pinned wires
into the under bonnet fuse box . as per instructions below.
Here is the Microimage instructions
Old 09-19-2009, 10:11 AM   #5
kuyachris84
lights won't turn on
Okay, I finished the install and I think I have everything installed correctly... but the fog lights will not turn on. Tell me if u see anything wrong.
Connected red wires from fogs to the two red wires that goes into pin1 and pin2 slots in the bonnet.
Here's the two pins plugged into the fuse box.
Here is the red wire from the switch going into the yellow wire (pin3) in the D4 connector under the steering wheel.
Here is the yellow wire from the switch going into an 'orange wire' from the dimmer switch. The diagram of the dimmer plug looks different than from the instructions. I didn't know what color to tap into ... I think someone said orange on the forum before. Let me know if that's the right wire.
Here my Indicator on my dash says my fog lights are on when i press the switch but the fog lights don't turn on. =(
Help, please!
Old 09-19-2009, 12:30 AM   #6
kuyachris84
Originally Posted by Nachtmensch View Post
I already checked that thread .. that's wut I based my install on... but my wiring looks / seems different
Sedan Fog Lights, few questions!(where to get) ( make into HID Fog Lights!!!) Lafiro Cosmetic Modifications (Exterior/Interior) 2 06-12-2009 03:56 PM
Disabled DRLs and Factory fog lights DARKYARIS DIY / Maintenance / Service 21 05-01-2007 05:32 PM
can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. fantabulousbaby Cosmetic Modifications (Exterior/Interior) 22 08-29-2006 01:13 PM
Fog lights for S sedans (US version) paeko73 General Yaris / Vitz Discussion 11 07-02-2006 11:38 PM
