#1 | |
![]() ![]() ![]() Drives: 2008 Yaris Liftback Black Join Date: Oct 2008
if its not too much too ask. .. pls ^^
2008 YARIS/VITZ LIFTBACK - BLACK SAND PEARL Representing The Midwest! http://www.cardomain.com/ride/3132598 |
#2 | |
jion it to the red wire comeing from the fog lights , then plug those 2 pinned wires into the under bonnet fuse box . as per instructions below. Here is the Microimage instructions |
lights won't turn on
Okay, I finished the install and I think I have everything installed correctly... but the fog lights will not turn on. Tell me if u see anything wrong.
![]() Connected red wires from fogs to the two red wires that goes into pin1 and pin2 slots in the bonnet. ![]() Here's the two pins plugged into the fuse box. ![]() Here is the red wire from the switch going into the yellow wire (pin3) in the D4 connector under the steering wheel. ![]() Here is the yellow wire from the switch going into an 'orange wire' from the dimmer switch. The diagram of the dimmer plug looks different than from the instructions. I didn't know what color to tap into ... I think someone said orange on the forum before. Let me know if that's the right wire. ![]() Here my Indicator on my dash says my fog lights are on when i press the switch but the fog lights don't turn on. =( Help, please!
| Sedan Fog Lights, few questions!(where to get) ( make into HID Fog Lights!!!) | Lafiro | Cosmetic Modifications (Exterior/Interior) | 2 | 06-12-2009 03:56 PM |
| Disabled DRLs and Factory fog lights | DARKYARIS | DIY / Maintenance / Service | 21 | 05-01-2007 05:32 PM |
| can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. | fantabulousbaby | Cosmetic Modifications (Exterior/Interior) | 22 | 08-29-2006 01:13 PM |
| Fog lights for S sedans (US version) | paeko73 | General Yaris / Vitz Discussion | 11 | 07-02-2006 11:38 PM |
