okay the fourth photo from the bottom (^above ) shows the fog light harness coming from the lights
join that to the 2 wires in the fuse box under bonnet , make sure the fog lights are earthed , that is all that is reqired under the bonnet . Throw every thing else away . Lights should work , if your dash symbol is lighting up if they are not check your fuses number 12 under dash and check that you have power at pin 1 & 2 under bonnet No power there means fuse blown , power there but still no lights means your connections made under bonnet are not connect ( joined properly ) Ps don't jump you will live to reget it |
#2 | |
![]() ![]() ![]() Drives: 2008 Yaris Liftback Black Join Date: Oct 2008
So if the indicator isn't working fuse 12 is blown. If pin 1 and pin2 has no power... where would the fuse for that be?
2008 YARIS/VITZ LIFTBACK - BLACK SAND PEARL Representing The Midwest! http://www.cardomain.com/ride/3132598 |
under the relay and wire panel, inside the car just above drivers feet
| Sedan Fog Lights, few questions!(where to get) ( make into HID Fog Lights!!!) | Lafiro | Cosmetic Modifications (Exterior/Interior) | 2 | 06-12-2009 03:56 PM |
| Disabled DRLs and Factory fog lights | DARKYARIS | DIY / Maintenance / Service | 21 | 05-01-2007 05:32 PM |
| can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. | fantabulousbaby | Cosmetic Modifications (Exterior/Interior) | 22 | 08-29-2006 01:13 PM |
| Fog lights for S sedans (US version) | paeko73 | General Yaris / Vitz Discussion | 11 | 07-02-2006 11:38 PM |
