Old 09-20-2009, 01:06 PM   #1
kuyachris84
kuyachris84's Avatar
Drives: 2008 Yaris Liftback Black
I got it working... FINALLY!!!!
I reattached the old relay. Those 3 wires had to go somewhere....
So pretty much attach the long red single wire to ray's oem kit. (2 wires that go into pin 1 and pin 2 in the engine bay fuse box) With the old relay i attached the red wire coming out of it to the battery. It has a fuse along with it. Installed the other relay inside the car where the fuses are at. Install the inside switch via ground and red wire to the yellow d4 wire at pin #3.
Note: I didn't install the yellow wire (coming out of the switch inside the car) as it also didn't allow my fogs to turn on when they were spliced into both the yellow d4 wire or the dimmer wire. So I left the yellow wire from the switch inside the car hanging and taped off.
Now when I press the switch inside the car... the fog lights turn on! and off when I press it again. Now I just gotta mount it... but i'll take pics later tonight!
Only problem is the switch for the fog lights stays on... but I doubt that'll drain my battery.
Those instructions you gave me were good but it doesn't say anything about what to do with the wires once you remove the relay (the relay coming from the wires... not the relay you put inside)... nor does it say to do anything with it. To a complete noob like me ... it will confuse people. It doesn't say to tape it off or connect it anywhere. I'm just relieved I got it to work. Anyone have questions ... please feel free to ask.
2008 YARIS/VITZ LIFTBACK - BLACK SAND PEARL
Representing The Midwest!
http://www.cardomain.com/ride/3132598
kuyachris84 is offline   Reply With Quote
Old 09-20-2009, 11:07 PM   #2
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
The relay you hooked up to the battery is not meant to be used , nor are the wires that where attached to it , you are now running your lights off
2 realys .
Sedan Fog Lights, few questions!(where to get) ( make into HID Fog Lights!!!) Lafiro Cosmetic Modifications (Exterior/Interior) 2 06-12-2009 03:56 PM
Disabled DRLs and Factory fog lights DARKYARIS DIY / Maintenance / Service 21 05-01-2007 05:32 PM
can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. fantabulousbaby Cosmetic Modifications (Exterior/Interior) 22 08-29-2006 01:13 PM
Fog lights for S sedans (US version) paeko73 General Yaris / Vitz Discussion 11 07-02-2006 11:38 PM
