JDM Fred
Basicall you need to replace your fluids, replace filter, spark plugs, rotate tires if needed, replace cabin air filter, check brakes, brake flush, cooling flush
#2 | |
manual transmission is to be done at 40000mi, sparks to be done near 60k, coolant closer to 70k. |
#3 | |
I seriously have to question if you actually work at a dealership. How on earth can you recommend maintenance 3 times earlier than the manual recommends?? "Here, let me give you this book explaining everything that needs to be done with your car, along with a detailed scheduled maintenance guide, but when you come in for maintenance, I'll contradict everything written inside."
| 2007 Yaris S 5spd Sedan doing 300,000 miles in less than 2 1/2yrs. | trini_per4mance | General Yaris / Vitz Discussion | 100 | 06-08-2022 09:54 PM |
| 4-wheel alignment for 5000 mi. maintenance????? | Yari-Chan | General Yaris / Vitz Discussion | 44 | 01-28-2011 09:00 PM |
| What's ur longest drive in a Yaris without stopping(cept gas)? | Yawesh | General Yaris / Vitz Discussion | 46 | 04-21-2009 01:36 PM |
| Synthetic Oil | Kaotic Lazagna | DIY / Maintenance / Service | 122 | 09-20-2007 03:40 PM |
