Old 09-23-2009, 02:24 PM   #1
IllusionX
Drives: 07 Yaris Sedan Aero
Originally Posted by RacerFreakXXX View Post
Basicall you need to replace your fluids, replace filter, spark plugs, rotate tires if needed, replace cabin air filter, check brakes, brake flush, cooling flush
wtf? where did you read that? there's nothing to do except checking brakes and filters. and the usual oil change.
manual transmission is to be done at 40000mi, sparks to be done near 60k, coolant closer to 70k.
Old 09-23-2009, 05:07 PM   #2
supmet
Drives: 2007 4 Door Yaris
Agreed, except coolant and sparks are suggested at 100k in the manual and maintenance guide that came with my car. Sounds like he is just trying to steal money from consumers like most of the other dealerships. Brake flush at 30k? You realize brakes are a hydraulic system right? Unless you are taking your car to the track and boiling your fluid, even changing it at 100k is a waste, but not a bad idea anyway since you can do it so cheap DIY.
I seriously have to question if you actually work at a dealership. How on earth can you recommend maintenance 3 times earlier than the manual recommends?? "Here, let me give you this book explaining everything that needs to be done with your car, along with a detailed scheduled maintenance guide, but when you come in for maintenance, I'll contradict everything written inside."
2007 Yaris S 5spd Sedan doing 300,000 miles in less than 2 1/2yrs. trini_per4mance General Yaris / Vitz Discussion 100 06-08-2022 09:54 PM
4-wheel alignment for 5000 mi. maintenance????? Yari-Chan General Yaris / Vitz Discussion 44 01-28-2011 09:00 PM
What's ur longest drive in a Yaris without stopping(cept gas)? Yawesh General Yaris / Vitz Discussion 46 04-21-2009 01:36 PM
Synthetic Oil Kaotic Lazagna DIY / Maintenance / Service 122 09-20-2007 03:40 PM
