Old 09-24-2009, 12:54 AM   #1
IsLNdbOi
IsLNdbOi's Avatar
So are Tanabe coilovers considered "budget"? I don't even know how much they are.
Still not sure whether to go w/ coilovers or the lowering springs. I'd be using the lowering springs w/ the stock struts / shocks.
Again, anyone know if coilovers require modified bumps stops like lowering springs do or does it depend on what height you adjust coilovers to?
Old 09-24-2009, 01:39 AM   #2
YaYa1320
YaYa
YaYa1320's Avatar
I had tein springs and cut the front bump stops in half, never had a problem. I have Megan coilovers now and they have their own bumpstops on 'em, but you shouldnt need to do anything to them, I installed coilovers, am tucking tire, 205/50/15 kumho ast, on Rota Slipstream, 15x6.5, they are adjusted very low and very stiff and I have no rubbing or bottoming out, to my liking of course, although the best thing about coilovers is you can ADJUST them!!!
YaYa1320 is offline   Reply With Quote
Old 09-24-2009, 01:42 AM   #3
YaYa1320
YaYa
YaYa1320's Avatar
P.S. also added camber bolts to front to negate any rubbing issues, added 2.5 negative camber, this is a must with my current rim/tire setup to tuck tire, maybe with a 195 width it wouldnt be a neccesity
Old 09-24-2009, 01:49 AM   #4
Tamago
Tamago's Avatar
Drives: UZJ100
yes, tanabe is budget.
what to look out for when installing lowering springs songa Performance Modifications 34 09-15-2012 03:29 AM
tanabe nf210 vs. TRD lowering springs?? static808 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 37 01-23-2012 11:00 PM
Lowering Springs - Questions ~ AGAIN ~ jaspie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 01-16-2007 12:23 AM
Will putting new lowering springs damage original shock absorbers in the long run? Joel Leong Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 06-07-2006 08:30 AM
