Who said Yaris was slow?
6000km and you want to wash it?
Even if you are in a sandy environment you don't want to clean a K&N element that often. Did you read the instructions on the filter when you installed it? A K&N filter actually needs some dust build up to properly work. A Just clean/new filter will filter less than one with some dust built it. I would tell you not to wash it more than once a year. Oh and regarding the washing process. Do you have the K&n cleaning kit? The instructions are on the box? Stay AWAY from compressed air... it would destroy the fibers on the filter. Just use warm tap water to remove the dust and then re-oil untill the filter looks red again. If your filter still looks red then you are not even close to needing a wash. |
#2 | |
![]() ![]() Drives: yaris sedan 2NZ-FE Join Date: May 2007
in terms of miles/km ... when should i service the filter? and about compressed air , i already did it once without knowing that its wrong , should i have it replaced or something? |
If you want to be conservative you can clean it every 15,000-20,000kms if you are in a very dusty enviroment. However that is still wya less than what K&N recommeds...
Here is some good reading for you: http://www.knfilters.com/faq.htm#4 If you only clean it once with compressed air is probably still ok. just don't do it again. That's a wet filter. The dust is trapped in the oil you won't get it loose with air... you will only break the thin cotton fibers. Don't panic when you see the filter all brown.... that's the way it is supposed to be. |
| Greddy xB kit vs Greddy Fit kit | ellenbetty | Forced Induction Forum | 52 | 09-29-2009 08:42 PM |
| Power Enterprise Super Charger Kit Round 2 $3100 | Power Enterprise Evan | Forced Induction Forum | 312 | 03-26-2009 06:48 PM |
