View Poll Results: Which is better?
Supercharged Yaris 30 28.85%
Turboed Yaris 74 71.15%
Voters: 104. You may not vote on this poll
Old 09-27-2009, 11:20 PM   #37
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
spools up?
Old 09-28-2009, 12:20 AM   #38
etheliters
etheliters's Avatar
Drives: 07 yaris hatch
Hey why'd you edit? It was informative, I looked for chinocharles but couldn't find his car anymore.? From what you erased it did make me think. If you coud get to 170 s/c'd then that would seem good. I thought a turbo would just be a better gain and leave you more powerful in the final result. Na poop, I meant pulls up. Figured turbo will catch and eat a s/c in most cases. Let me know.
etheliters is offline   Reply With Quote
Old 09-28-2009, 12:36 AM   #39
RacerFreakXXX
JDM Fred
Drives: 06 Mazda Miata
Send a message via AIM to RacerFreakXXX
I highly doubt you could get the blitz supercharger up to that much unless you were running 14+psi, fully tuned, and a built motor.
Anywho, I would love to have a turbo kit; just no time or balls to piece one together. Come on MI, hurry up at make a sick kit with a map for 180whp. :P I got money at hand.
Actually, Peter... you said you had money for a turbo, why don't you build your motor up? If you have the money and could make some time, I think it would be awesome to see what a supercharger would do on an engine like garm's but keep the 10.0:1 compression... or maybe even bump it up to 11.0:1.
RacerFreakXXX is offline   Reply With Quote
Old 09-28-2009, 12:43 AM   #40
puetato89
Just call me Ray, better?
puetato89's Avatar
Drives: 08 Yaris
yeah and blow the motor peter, its all kool as long as you give the S/C i can pay for shipping
Old 09-28-2009, 01:35 AM   #41
PETERPOOP
PETERPOOP's Avatar
Cali yaris was running I think only 10psi and at 180 whp non built motor and ran fine for a year. I am at 8psi and could add acouple more lbs of boost with an overdrive crank pulley or a fixed pulley. Tuned and it could reach 170whp I think. Never know....but i'm going to find out in due time. :)
I do have the money, but definately not the time. I'm a full time student and I work construction. I won't be the man to be doing a built motor anytime soon.
I deleted it because I was over it. Chinocharles probably deleted his info on his car. He pretty much said he had 180whp (according to ZPI's dyno ) and he finally dyno'd it and found out it made 145whp. lmao. He also deleted the info because he had a hissy fit and got banned from the forums. lmao x2.
Well the turbo can only pull up when it spools up. hehe
If I ever blew my engine up (which could be a possibility when I tune ), i'll sell you the S/C. You got dibs.
Old 09-28-2009, 02:31 AM   #42
puetato89
puetato89's Avatar
Drives: 08 Yaris
sell or give
Old 09-28-2009, 04:02 AM   #43
anonymous user
rarer than JDM -1 of 1!
anonymous user's Avatar
Drives: 07yaris
Best? For what?
It's not what you drive, or how much $$ you throw at the car. Mod the ballast on the front left first!
anonymous user is offline   Reply With Quote
Old 09-28-2009, 10:37 AM   #44
puetato89
puetato89's Avatar
Drives: 08 Yaris
i guess its "in general"
Old 09-28-2009, 06:40 PM   #45
RacerFreakXXX
JDM Fred
Peter -
yea I know the deal, I finally got a 9-5 job but I'm in debt till spring so I got's no money. I'd love to see you even pull 150whp out of your car. I do know there was this site that would build a head and cams for you and refund some of the money when you send them your head and cams back. I saw it on the micro image forums, I'm sure you know what I'm talking about. That may be an option but, I know it's like 3k or something around there.
Old 10-12-2009, 10:07 PM   #46
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
let me chime in on this one, I have had the Blitz sc on my 1nz xA. I can tell you that is definately NOT more realiable than a decent turbo set-up. It left me on the side of the road a few times. I assume the Yaris is the same, it comes with a 4pk belt width? And the crank pulley is not keyed, what keeps it from rotating on the crank shaft is nothing but an 1/8" roll pin. I went through every brand of belt to find one sticky enough to not slip and strong enough to not stretch. And when I got it to where the belt stopped slipping, the crank pulley roll pin shears. Its a pain drilling it out. I found that a high quality hardened drill bit (round end) works best as it doesnt shear as easily. The consisancy of performance bugged me as the belt had to be constantly re-tensioned and checked or boost is lost or if it was too tight it would bind and power was lost. I had about 40,000 supercharged miles.
I then went with the Greddy turbo kit. I have had that kit on for over 50,000 miles of time attacks, auto crosses, and drags strip time... and driving everywhere in between. The only problem I ever had with the turbo set-up was cracking the downpipe, which was due to a shotty custom exhaust with the flex section half way back under the car.
I am pushing 20 psi with my old Greddy kit now and it's still kickin. I did some improvements to get more out of the tiny turbo such as a better intake, blow through MAF set-up, 2.5" downpipe (2" original) and 3" exhaust, also meth injection. So far so good
Blown_xa is offline   Reply With Quote
Old 10-12-2009, 10:24 PM   #47
frownonfun
frownonfun's Avatar
ok ok thinking about it after the fact my post was a little too much. i had just read a few posts on the first page that struck a nerve. obviously i've read similar posts in the past knocking other users' pursuit of the fabled "fast yaris" and, idk, tonight it just got a little old. but anyway i apologize for being an ass. carry on.
btw i voted s/c.
EDIT: bad frownonfun
I crush you like tiny clown car, because you are clown, yes?
Old 10-12-2009, 10:52 PM   #48
PETERPOOP
PETERPOOP's Avatar
lmao. frownnofun, where the heck did that come from?
Old 10-12-2009, 10:53 PM   #49
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
If you are going to go s/c'd then get the PE kit. IMO it was worth the hassles of the install make sure you have a extra car if you need to make runs to the parts stores and shops.
Old 10-12-2009, 11:02 PM   #50
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
+100! Frown is one of the most laid-back guys I know. Wow.
Old 10-12-2009, 11:04 PM   #51
ozmdd
ozmdd's Avatar
Originally Posted by JCS_IMPORT_25 View Post
Lets have a vote.
which is best.
Supercharged Yaris
Turboed Yaris
:eyebulg e::wink ::t ongue:
I'm sorry, but where is choice #3: "Turbo" badge w/ interfooler??
Old 10-14-2009, 03:42 PM   #52
hatchbackkid82
Drives: .
I don't think a 175whp Yaris could take an EVO, I love my car but i know when it's out gunned. He would get you off the launch, even if your running slicks
Originally Posted by scape View Post
a 175 hp yaris would practically beat out a lancer evo... i'd say that's a great turbo option haha
Old 10-14-2009, 10:21 PM   #53
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
This has been a fun thread to read. I vote turbo because there is nothing like a turbo kicking on and that torque steer snapping your car 4 feet sideways. That was one of the absolute most fun feelings I've ever had driving.
Saying that I think I'd invest in figuring out how to make my Yaris AWD before adding a turbo. Then when I had the power I could use it well.
Colin Chapman disciple
Old 10-17-2009, 08:23 PM   #54
RacerFreakXXX
JDM Fred
IMO the only good awd car for racing is a rwd/awd setup like the evo or gtr. FWD is not bad, especialy on light weight hatches.
I have grown to love both turbo and supercharger. They both have their ups and downs and are better suited for different applications. I have decided supercharger for my situation unless a inexpensive small bolt on turbo kit was available but that may never happen.
Turbo Project Yaris TS 1.8L CASTREX Yaris TS Talk 40 08-21-2009 10:24 AM
HKS turbo timer type 1 Tamago Performance Modifications 3 07-21-2009 11:59 AM
Turbo Kit - trade for stock parts! crankyelbow Items for Sale by private party 62 02-03-2009 12:30 PM
delayed turbo project... joey1320 Forced Induction Forum 8 09-26-2007 11:18 PM
Vitz Rs turbo vs U.S. Yaris add turbo? weaponrcamry Performance Modifications 18 08-09-2006 08:45 PM
