Old 09-29-2009, 11:05 AM   #1
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
Anywhere from 1 to 2 degrees of negative camber up front should give a nice street set-up. You can purchase non-adjustable camber bolts from rockauto.com very cheap. I'm not sure how much, if any adjustment you can make without the use of camber bolts. While 0 degrees toe-in is preferred for performance, a very slight toe-in (1/16") will make the car track much better at highway speeds.
Old 09-29-2009, 12:28 PM   #2
ddongbap
Toe out helps with speeds, not in. It seems like thats what you meant tho.
Old 09-29-2009, 08:40 PM   #3
Tamago
Tamago's Avatar
Drives: UZJ100
no you're wrong
toe in = high speed stability.
Old 09-30-2009, 12:08 AM   #4
ddongbap
no you're wrong
I am corrected.
Old 09-29-2009, 08:55 PM   #5
ozmdd
ozmdd's Avatar
Tamago is correct, toe out improves turn-in, not tracking straight. Toe-in basically points the wheels towards each other, so the car is "trying" to steer to the center, toe-out has both wheels pulling away from each other, or constantly "fighting" each other. Whichever way you favor, the car will move more quickly in that direction.
Tamago's guide to ultimate yaris handling Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 99 01-25-2026 12:51 PM
24mm sway in front and 23mm in the rear fuji Performance Modifications 28 11-13-2012 05:02 AM
Positives and negatives to hub spacers? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 11-11-2009 07:37 AM
In regards to understeer....... anonymous user Wheels, Tires and Suspension Forum sponsored by The Tire Rack 56 05-31-2009 10:38 AM
Taking to next level and eliminate understeer regal Wheels, Tires and Suspension Forum sponsored by The Tire Rack 23 05-25-2009 07:19 PM
