Old 09-29-2009, 04:41 PM   #1
DOMAV
Drives: Yaris 09 T-spirit 1.33
why do you change the camber bolts? what do they have different from stock?
DOMAV is offline   Reply With Quote
Old 09-29-2009, 09:02 PM   #2
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
Camber bolts, particularly the nice ones like Garm sells - have an eccentric lobe on the shank (like a camshaft) where it fits through the strut bracket. By adjusting the position of the lobe, you tilt the bottom of the strut "in" or "out" from vertical, and the hub/wheel goes with it. Viola! - camber!
The stock bolt you replace is exactly that; a regular bolt that doesn't have adjustability.
I hope that helps.
Tamago's guide to ultimate yaris handling Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 99 01-25-2026 12:51 PM
24mm sway in front and 23mm in the rear fuji Performance Modifications 28 11-13-2012 05:02 AM
Positives and negatives to hub spacers? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 11-11-2009 07:37 AM
In regards to understeer....... anonymous user Wheels, Tires and Suspension Forum sponsored by The Tire Rack 56 05-31-2009 10:38 AM
Taking to next level and eliminate understeer regal Wheels, Tires and Suspension Forum sponsored by The Tire Rack 23 05-25-2009 07:19 PM
