Old 09-30-2009, 07:01 AM   #1
Tamago
Tamago's Avatar
Drives: UZJ100
Originally Posted by DOMAV View Post
Hi all thanks for all the help, so first a get the yaris aligned, then i do the rear sway bar! what will the front upper strut do? will it help?
as far as the alignment what is the factory setup? i think the garage guy will know but better if i know so i'll tell him thanks all for the help
you don't want the factory setup. you want -1.5 degrees camber up front, 0 toe.
the rear you can't mess with without shims.
go read the "ultimate suspension guide" before you throw money away on a front upper strut bar.
Tamago's guide to ultimate yaris handling Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 99 01-25-2026 12:51 PM
24mm sway in front and 23mm in the rear fuji Performance Modifications 28 11-13-2012 05:02 AM
Positives and negatives to hub spacers? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 11-11-2009 07:37 AM
In regards to understeer....... anonymous user Wheels, Tires and Suspension Forum sponsored by The Tire Rack 56 05-31-2009 10:38 AM
Taking to next level and eliminate understeer regal Wheels, Tires and Suspension Forum sponsored by The Tire Rack 23 05-25-2009 07:19 PM
