Old 09-30-2009, 04:03 PM   #1
birdman
Drives: '08 Blazing Blue Yaris LB
Thanks for all your insights. I seem to remember an article that placed the resister in the wiring coming off of the head light assemblies under the hood (bonnet). Not having to tear apart the dash would be a real plus. But if tearing the dash apart to do it is what I have to do then so be it. I'm after an inconspicuous fix.
birdman is offline   Reply With Quote
Old 09-30-2009, 04:51 PM   #2
A resistor can be added in series with the circuit to avoid having to disassemble the cluster. You could potentially cut into where the signal routes through Connector BA1 under the hood, but it would be easier to add the resistor at the connector entering the cluster. You would cut the gray wire in position 14 and add a resistor between the cut wire. I would start at about 1K Ohms and go up from there to find a desirable brightness.
F/S Blue Stitched Leather Shift Boot. 1NZYaris1 Items for Sale by private party 9 05-06-2009 11:59 PM
Bayou Blue paint code andru47 General Yaris / Vitz Discussion 7 01-03-2009 04:19 PM
Blue Film over gauges Jeff1 DIY / Maintenance / Service 10 10-21-2008 03:01 PM
Black or Blue CrashRescueFF New YARIS Purchase Forum 18 07-24-2007 07:21 PM
Nautical Blue Metallic YotaYarisUSA General Yaris / Vitz Discussion 0 04-02-2006 07:09 PM
