Old 09-30-2009, 08:29 PM   #1
birdman
Drives: '08 Blazing Blue Yaris LB
CTScott you are too much man. You must possess an extra chromosome or something. When you spliced the gray wire was the gauge assembly still in the car? If not How do you remove it? Do you have a photo of the 2k resister in place? Does it need soldering? Does it matter which end of the resister is closest to the D2 connecter?
birdman is offline   Reply With Quote
Old 09-30-2009, 08:54 PM   #2
I tested it out on Crashy (my ebay purchased totaled Yaris), who has no headlights, so i actually jumped power to the indicator to make it light and then added the resistor inline with the jumper. I also have her dash completely removed, so I have easy access to all wiring.
But, to do this on an intact car, you pop the cluster trim, disconnect the connector, and then cut the resistor into the wiring harness. You'll cut the wire (about 2" from the connector to give yourself room to work), strip both ends, attach one end of the resistor to each (resistors aren't polarized, so it doesn't matter which end goes to which), and then either heat shrink it or tape it up.
F/S Blue Stitched Leather Shift Boot. 1NZYaris1 Items for Sale by private party 9 05-06-2009 11:59 PM
Bayou Blue paint code andru47 General Yaris / Vitz Discussion 7 01-03-2009 04:19 PM
Blue Film over gauges Jeff1 DIY / Maintenance / Service 10 10-21-2008 03:01 PM
Black or Blue CrashRescueFF New YARIS Purchase Forum 18 07-24-2007 07:21 PM
Nautical Blue Metallic YotaYarisUSA General Yaris / Vitz Discussion 0 04-02-2006 07:09 PM
