Old 10-01-2009, 04:53 PM   #1
Marfulion
Drives: 2008 Yaris Sedan
How much abuse can the Yaris take?
Well technically the yaris isnt mine but the car has about 31000 miles on it and 95% of those miles were all me. It is kinda like a company car. I have this car at full throttle almost all the time and I force the downshifts on the auto trans like before every corner. Also every now and then I launch while the auto stick is in "L" and push it up to 2nd right before it hits revlimit, cus normaly it shifts like 250rpms before the redline on "D" and i do same from 2nd to 3rd. So my question is how long before the transmission or the engine goes out if i continue to drive it abusively like that?
Marfulion is offline   Reply With Quote
Old 10-01-2009, 05:03 PM   #2
ddongbap
You should be ok. I don't recommend shifting the tranny very often. Es no bueno.
Old 10-01-2009, 05:56 PM   #3
supmet
Drives: 2007 4 Door Yaris
I would suggest shifting at least twice each time you go from 0-60
Old 10-01-2009, 07:51 PM   #4
ddongbap
Its an automatic bro.
Old 10-01-2009, 07:53 PM   #5
supmet
I assure you, automatic transmissions still need to shift.
Old 10-01-2009, 08:02 PM   #6
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Driving with such reckless abandon will sooner or later bite you in the butt as some other driver is going to do something unexpected and the accident will occur because you have left no room for other peoples driving errors.If you really want to let it all out take it to the track where you'll probably find out you arent the driver you think you are..
Old 10-01-2009, 08:08 PM   #7
ddongbap
So, you're suggesting to the tranny that it should shift?
Old 10-02-2009, 12:42 PM   #8
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
A more accurate statement would be that you *can* shift an automatic to address certain driving conditions (heavy loads, poor road conditions), but if you make it a routine and drive it like a manual, then why bother with an auto at all?
They were designed and meant to be put in drive and go hence the term "automatic".
To the OP - regardless of whether or not the car can take the abuse, unless you own it and pay for it you shouldn't be doing that.
Old 10-01-2009, 05:13 PM   #9
yarr_is
Drives: yaris
drive it like you stole it =]
yarr_is is offline   Reply With Quote
Old 10-01-2009, 06:30 PM   #10
IllusionX
Drives: 07 Yaris Sedan Aero
why would you do this to a car?
Even the chevy uplander i had as a company car did not take such abuse.
Old 10-01-2009, 06:49 PM   #11
tomato
tomato's Avatar
I was wondering the same thing actually.
Old 10-01-2009, 07:36 PM   #12
BECAUSE
Old 10-01-2009, 07:49 PM   #13
firebob
Drives: 09 yaris
It’s great on dirt (a little gravel on the sides) roads. Just have to watch out for bumps and crowns in the road. I have gotten it stuck twice on the crown of the road .
09, 3 door lift back, auto. I live on the road with my wife. We travel as needed for our work and drive up to 4,500 miles in a bad week.
firebob is offline   Reply With Quote
Old 10-01-2009, 07:02 PM   #14
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
I guess you'll find out when you hear something crunch.
Old 10-01-2009, 07:03 PM   #15
birdman
Drives: '08 Blazing Blue Yaris LB
Drove her over a cliff a few times and she always bounced back. Nare a scratch!
birdman is offline   Reply With Quote
Old 10-01-2009, 07:18 PM   #16
Sabretooth
37HSSV
Sabretooth's Avatar
Drives: '11 Mazdaspeed 3
Ok....Ill give you an honest answer, instead of this flame war...
If you are kidding about this thread, congratz. You started your own little fun thread, focused on something stupid.
If you are serious, you really need to consider what I am about to post.
Ok,
To start, the Yaris is an economy car, not a sports car. Just because it has 2 doors and goes vroom, doesnt mean that it is of sports characteristics. What makes this car fun to drive is more that it corners well for what it is, an entry level "slushbox" if you will, that people mock us for driving, doenst matter if they own a 350Z or a Civic Si, they still thing the concept of driving our car fast is funny. Because they know that we only have a small amount of HP to offer and pretty much nothing to really pull out of the engine N/A.
Now as for reliability...Toyota has been making the NCP platform/chassis for about 10 years, Started it all off with the Echo, then created the Scion Xa/Xb platforms, all using the same engines, trannys, and so on. Now, as for the most recent engines. The newer drive by wire setups, they are still as reliable as the previous. Yet keep in mind, This is an ECONOMY Car, This car was no developed to out perform, well anything. It was simply designed and built to commute, save gas, and have just enough get-up-n-go to just get on the highway and a little more.
As for all cars, the harsher you treat it, majority of the parts will break prematurely. Instead of them making a long life of 375k miles (YES, it has been documented, video'd on this forum of a Yaris lasting this long) or more. You will start seeing issues earlier than such.
In all said, If you are willing to beat this car daily, thrashing it as if it were an Indy car. Dont expect for it to make it to a longer lifespan as if you treated "nicer". Oh, if you continue, you might want to try and take extra precautions to your maintenance schedule...Synthetic Oil, Transmission fluid, etc. Just so your not causing more strain on parts that are already being pushed to a limit that the manufacturer never intended directly on a regular basis.
Oh, and if you need an example...My last car, even though it wasnt a Toyota, I drove similar to what you are now. My transmission didnt last past 80,000 miles. Needed to be rebuilt, but I rather traded it in on its last leg of life for my Yaris. My driving isnt the kindest towards my car, but I no where drive the Yaris as hard as I did my last vehicles.
Old 10-01-2009, 07:28 PM   #17
Sir A.Y. Atoyot
Sir A.Y. Atoyot's Avatar
Drives: '08 5-door
Driving that way is extremely immature. If you want to use up excess energy, do it in a more constructive way, is my advice.
Sir A.Y. Atoyot is offline   Reply With Quote
Old 10-01-2009, 07:57 PM   #18
AlexNet0
AlexNet0's Avatar
^ ok tamago and rockland, haha
