Old 10-01-2009, 07:51 PM   #1
ddongbap
Originally Posted by supmet View Post
I would suggest shifting at least twice each time you go from 0-60
Its an automatic bro.
Old 10-01-2009, 07:53 PM   #2
supmet
Drives: 2007 4 Door Yaris
I assure you, automatic transmissions still need to shift.
Old 10-01-2009, 08:02 PM   #3
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Driving with such reckless abandon will sooner or later bite you in the butt as some other driver is going to do something unexpected and the accident will occur because you have left no room for other peoples driving errors.If you really want to let it all out take it to the track where you'll probably find out you arent the driver you think you are..
Old 10-01-2009, 08:08 PM   #4
ddongbap
So, you're suggesting to the tranny that it should shift?
Old 10-02-2009, 12:42 PM   #5
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
A more accurate statement would be that you *can* shift an automatic to address certain driving conditions (heavy loads, poor road conditions), but if you make it a routine and drive it like a manual, then why bother with an auto at all?
They were designed and meant to be put in drive and go hence the term "automatic".
To the OP - regardless of whether or not the car can take the abuse, unless you own it and pay for it you shouldn't be doing that.
