Old 10-03-2009, 02:40 PM   #1
crxgames
Drives: 2005 Scion xB
Point me to the articles if you can find them. This would be very easy to do if I had some curves to grab data points from. And, it could be a $50 item.
As requested:
http://autospeed.com/cms/A_2658/article.html
http://autospeed.com/cms/A_2659/article.html
http://autospeed.com/cms/A_1458/article.html
http://autospeed.com/cms/A_2661/article.html
http://autospeed.com/cms/A_2664/article.html
http://autospeed.com/cms/A_2388/article.html
I link to all of these as there's good info in all of them. The last 2-3 links are the ones with most of the info though. If you make one of these, I wanna know!
crxgames is offline   Reply With Quote
Old 10-03-2009, 02:49 PM   #2
Originally Posted by crxgames View Post
As requested:
Very interesting!
Scanning through it I saw this:
So despite trying each of the following, consistent full-load mixtures could not be obtained:
* Intercepting the airflow meter signal with the DFA
* Altering fuel pressure
* Switching the oxy sensors in and out on the basis of throttle position
* Switching the oxy sensors out as fuel pressure was progressively increased
* Switching the oxy sensors out and intercepting the airflow meter signal with the DFA
* Switching the oxy sensors out, increasing fuel pressure and intercepting the airflow meter signal with the DFA
* Intercepting the oxy sensor signals with the DFA
* Disconnecting the oxy sensors at all loads and then setting the mixtures via the DFA working on the airflow meter signal
The solution in this article was to increase fuel pressure, rather than intercepting the airflow meter signals (and 02 sensors). My original thought was that you would need to fool the 02 feedback as well, but with the turbo Prius, even that wasn't consistent.
I'd really like to see some hard data on the Tom's to see if this is worth emulating.
Fuel Efficiency and the Yaris BailOut Fuel Economy Forum 327 01-02-2026 11:44 PM
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 03:34 AM
Blitz owners: fuel controller question s3r3nity Forced Induction Forum 28 05-30-2009 09:19 PM
Last Fuel Bar andaconda Fuel Economy Forum 37 04-29-2009 02:35 PM
Another S/C'd member worried about his AFR LtNoogie Forced Induction Forum 181 04-18-2009 12:19 AM
