Old 10-04-2009, 11:05 PM   #1
RUFFSTUFF
Drives: 2009 TOYOTA YARIS SEDAN
Why?
RUFFSTUFF is offline   Reply With Quote
Old 10-04-2009, 11:54 PM   #2
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Yes, the yaris can rock 13's
Do a search for lenso vpd and you'll see
Old 10-05-2009, 12:37 PM   #3
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
Originally Posted by RUFFSTUFF View Post
Why?
Smaller wheels/tires=less rotating mass. Lighter=faster acceleration.
Old 10-05-2009, 03:37 PM   #4
RUFFSTUFF
Nothing like buying a Yaris and then spending money to try to keep up with Corrollas...
The unsprung weight loss of the smaller wheel may (assuming wheel characteristics are the same i.e. not going from 15" alloy to 13" steel) improve handling characteristics, but is there much in the area of straight line performance gain? Except if you don't adjust the aspect ratio for the minus-2 sizing, then you will have higher gearing which will improve acceleration at the cost of top speed. Running a higher aspect ratio tire to compensate for the smaller wheel is sure to hurt cornering performance... as the tire shifts off-axis with the wheel.
Old 10-05-2009, 03:43 PM   #5
CASTREX
CASTREX's Avatar
Actually cornering is improved.
Removal of unsprung weight not only improve straight line acceleration, but also overall handling and breaking.
And what are you talking about keeping up with a Corolla? A Corolla can't keep up with a Yaris... not even in it's dreams...
Old 10-05-2009, 03:45 PM   #6
RUFFSTUFF
Removal of sprung weight not only improve straight line acceleration, but also overall handling and breaking.
Wheels are unsprung weight. Anything the weighs down the suspension is sprung.
Yaris vs. Corolla... Fight!
Old 10-05-2009, 04:00 PM   #7
CASTREX
CASTREX's Avatar
Yeah... edited. You got the point though.
Any way... the Yaris reacts very well to wheel/tire weight reduction.
Also a good point on the positive side of shortening the gearing. Not a good idea for a DD, but the Yaris would benefit of a shorter ratio for the track or autoX
Factory Miata wheels fit without modification? evan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 07-02-2015 08:01 PM
Black Yaris.. What wheels? buchieboy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 02-11-2009 06:03 PM
