I ordered the pins and i will install them, I will also use a clutch wire jumper to make sure the switch is ok. Hope that fixes it.
![]() Drives: Toyota Yaris Join Date: Apr 2007
My only problem with the cruise was the clutch switch, jammin connectors in the terminals on the fusebox connections never worked. Went through every connection in the entire car tracking down a loose crimp or a short didnt find anything. So I used quick splice connectors and actually tied into the wires for the clutch-switch, works great now.
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| Cruise Control - Again! | CB900F2 | DIY / Maintenance / Service | 47 | 06-17-2010 06:29 PM |
| Cruise Control | chessclubloser | DIY / Maintenance / Service | 11 | 03-27-2010 11:59 AM |
| Cruise control vs MPG | YarisOwnersDad | Fuel Economy Forum | 15 | 05-29-2009 03:55 PM |
| Using Cruise control | Driver | General Yaris / Vitz Discussion | 14 | 11-09-2006 10:12 PM |
