Old 10-05-2009, 05:59 PM   #1
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Originally Posted by TheRealEnth View Post
are you saying aftermarket rims/tires, if not adjusted to correct size, causes loss in top speed?
I think he was just going by the general rule of thumb.
Shorter ratios foe better acceleration and longer ratios for higher max speed... although is not as simple as that....
Old 10-05-2009, 06:44 PM   #2
RUFFSTUFF
Drives: 2009 TOYOTA YARIS SEDAN
Actually it is. If you change nothing but the diameter of the wheel and tire, acceleration and top speed will change accordingly. And oh yeah, your speedometer accuracy will also be affected. The diameter of your wheel and tire is based on the rim size, the tire width and the aspect ratio. This overall diameter multiplied by pi will give you an approximate rolling circumference. I say approximate because without taking a physical measurement, you're left with the manufacturer's size rating and they are not very good at providing good measurements. Tires labeled as the same size can actually be quite different, even within the same manufacturer. On my Mazda3sGT, I went from a 205/45-17 OEM to a 205/40-17 Fuzion tire. It was a noticeable change in acceleration (quickness). Top speed originally was limited to 114mph on the speedo (112mph GPS)... the rev limiter still kicks in at 114mph on the speedo, except that it is now only 105mph on the GPS. Keep in mind that speedos do not report actual speed, much like gas gauges don't report actual fuel level... only different. :)
RUFFSTUFF is offline   Reply With Quote
Factory Miata wheels fit without modification? evan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 07-02-2015 08:01 PM
FS: Yaris RS Alloy wheels W/Tires & Lugs mr.white_hb Items for Sale by private party 23 03-30-2009 10:40 PM
Black Yaris.. What wheels? buchieboy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 02-11-2009 06:03 PM
